Revision: 5152
Author: gruehle@adobe.com
Date: 2009-03-03 13:18:45 -0800 (Tue, 03 Mar 2009)
Log Message:
First pass of bug fixes for the Spark skins for Halo components.
Bugs:
SDK-19963 - themeColor should not affect rollOverColor or selectionColor in flex 4
SDK-19654 - Spark skin for the Halo ComboBox dropdown needs a drop shadow
SDK-19637 - Halo HScrollBar/VScrollBar controls dont render correctly when specifying includeIn states
SDK-19634 - Halo ProgressBar default size is very different when using Halo vs Gumbo theme
SDK-19626 - Flicker when toggling enabled property on Halo TabBar control with Gumbo skin
SDK-19556 - selected Halo CheckBox and RadioButton icons briefly flicker when you roll over them
SDK-19658 - Halo ComboBox with Gumbo skin has an odd flicker
Doc/QA Notes: The fix for SDK-19963 includes a compatibility-version check. When compatibility-version < 4, setting themeColor implicitly sets rollOverColor and selectionColor, if they have not been set. When compatibility-version >= 4, you must explicitly set rollOverColor and selectionColor, even when using the Halo theme.
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-19963
http://bugs.adobe.com/jira/browse/SDK-19654
http://bugs.adobe.com/jira/browse/SDK-19637
http://bugs.adobe.com/jira/browse/SDK-19634
http://bugs.adobe.com/jira/browse/SDK-19626
http://bugs.adobe.com/jira/browse/SDK-19556
http://bugs.adobe.com/jira/browse/SDK-19658
Modified Paths:
flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxApplication.as
flex/sdk/trunk/frameworks/projects/framework/defaults.css
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Button.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBase.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Application.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RectangularDropShadow.as
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/BorderSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ProgressBarTrackSkin.mxml
