0 Replies Latest reply on Mar 9, 2009 10:48 AM by Glenn Ruehle
    [svn:fx-trunk] 5209: More bug fixes for Spark skins for Halo components.
    Glenn Ruehle Adobe Employee
      Revision: 5209
      Author: gruehle@adobe.com
      Date: 2009-03-09 11:47:59 -0700 (Mon, 09 Mar 2009)
      Log Message:
      SDK-19724 - If you change themeColor at runtime, it does not affect rollOverColor and selectionColor even if you compile with -compatibility-version=3
      SDK-19719 - The top edge of a TabNavigator using a Spark skin doesn't look disabled when the container is disabled.
      SDK-19628 - Disabled TabBar and TabNavigator render differently when using Gumbo skins
      SDK-19627 - disabled Halo TabBar control not rendering correctly when using Gumbo skins
      SDK-19612 - disabled Halo DateChooser should set the alpha on the calendar icon when disabled
      SDK-19585 - Menus compiled with the halo theme in Flex 4 have a different border color than in Flex 3
      SDK-19718 - Spark Alert skin should allow for more space at the bottom (under the button(s))
      SDK-19649 - Default height of Halo RadioButton is different
      SDK-19648 - Default height of a halo CheckBox is different now.
      SDK-19615 - very difficult to tell if a Halo HSlider or VSlider with Gumbo skin is disabled
      SDK-19561 - FxSlider thumb is smaller than Slider thumb
      SDK-17416 - Setting the themeColor at runtime with the StyleManager does not affect rollOverColor.
      QA/Doc Notes: These changes are controlled by the compatibility-version flag:
      * Disabled container appearance:
      - old behavior: disabled containers dimmed the contents, but not the border
      - new behavior: disabled containers dim contents and the border
      * Slider thumb measurement:
      - old behavior: slider thumbs forced measured size to 12x12
      - new behavior: slider thumbs measured size dictated by skin
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-19724
      http://bugs.adobe.com/jira/browse/SDK-19719
      http://bugs.adobe.com/jira/browse/SDK-19628
      http://bugs.adobe.com/jira/browse/SDK-19627
      http://bugs.adobe.com/jira/browse/SDK-19612
      http://bugs.adobe.com/jira/browse/SDK-19585
      http://bugs.adobe.com/jira/browse/SDK-19718
      http://bugs.adobe.com/jira/browse/SDK-19649
      http://bugs.adobe.com/jira/browse/SDK-19648
      http://bugs.adobe.com/jira/browse/SDK-19615
      http://bugs.adobe.com/jira/browse/SDK-19561
      http://bugs.adobe.com/jira/browse/SDK-17416
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/defaults.css
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/sliderClasses/SliderThumb.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
      flex/sdk/trunk/frameworks/projects/halo/defaults.css
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/BorderSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/SliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/TabSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/TextInputBorderSkin.mxml
