0 Replies Latest reply on Mar 9, 2009 5:39 PM by (Ryan_Frishberg)
    [svn:fx-trunk] 5215: Initial checkin for FxVideoDisplay.
      Revision: 5215
      Author: rfrishbe@adobe.com
      Date: 2009-03-09 18:39:37 -0700 (Mon, 09 Mar 2009)
      Log Message:
      Initial checkin for FxVideoDisplay. FxVideoDisplay is the new skinnable video component in Gumbo. VideoElement is the new chromeless video component in Gumbo.
      As part of this checkin, a new swc was added to the libs directory, videoPlayer.swc, which holds the underlying FLVPlackback VideoPlayer we are using today in VideoElement.
      Multi-bit rate support hasn't been added yet, the skin could use a lot of work, and work needs to be done on state/skinstate support. Otherwise, most things should be working.
      QE Notes: You can start testing :-)
      Doc Notes: -
      Bugs: -
      Reviewer: Deepa
      tests: checkintests
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/defaults.css
      flex/sdk/trunk/frameworks/projects/flex4/manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/Flex4Classes.as
      Added Paths:
      flex/sdk/trunk/frameworks/libs/videoPlayer.swc
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxVideoDisplay.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/VideoElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVideoDisplayMuteButtonSkin. mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVideoDisplayPlayPauseButton Skin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVideoDisplaySkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/MetadataEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/VideoEvent.as
