0 Replies Latest reply on Mar 10, 2009 11:29 AM by (Paul_Reilly)
    [svn:fx-trunk] 5222: Initial MXML Vector support.
    Level 1
      Revision: 5222
      Author: preilly@adobe.com
      Date: 2009-03-10 12:29:18 -0700 (Tue, 10 Mar 2009)
      Log Message:
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-19214
      API Change: NO
      Reviewer: Pete F.
      Code-level description of changes:
      frameworks/projects/framework/manifest.xml
      frameworks/mxml-manifest.xml
      Added Vector component.
      modules/compiler/src/java/flex2/compiler_en.properties
      Moved mxml.builder.AbstractBuilder.NullArrayElementStoreType to
      mxml.reflect.TypeTable.ElementTypeNotFound.
      Added mxml.InterfaceCompiler.VectorTypeRequired, mxml.builder.VectorBuilder.WrongElementType
      modules/compiler/src/java/flex2/compiler/abc/Method.java
      Added getReturnElementTypeName() and getParameterElementTypeNames().
      modules/compiler/src/java/flex2/compiler/abc/Variable.java
      Added getElementTypeName().
      modules/compiler/src/java/flex2/compiler/as3/reflect/Method.java
      Added parameterElementTypeNames and returnElementTypeName
      variables, modified constructor to initialize them, and added
      getters for them.
      Removed one line functionName() and refactored functionTypeName()
      into extractFunctionTypeInfo().
      modules/compiler/src/java/flex2/compiler/as3/reflect/Variable.java
      Added typeName variable, modified constructor to initialize it,
      and added getter for it.
      Removed variableName() and refactored variableTypeName() into
      extractVariableTypeInfo().
      modules/compiler/src/java/flex2/compiler/as3/reflect/TypeTable.java
      Modified createParameters() to handle the parameter element type names.
      modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      Added generateApplyTypeExpr() and modified
      generateTypeExpression() and generateVariableNew() to use it for
      Vector support.
      modules/compiler/src/java/flex2/compiler/SymbolTable.java
      Added VECTOR and added getElementTypeName() to NoType class.
      Modified getClass() to handle Vector.
      modules/compiler/src/java/flex2/compiler/mxml/dom/Analyzer.java
      modules/compiler/src/java/flex2/compiler/mxml/dom/AnalyzerAdapter.java
      Added analyze(VectorNode).
      modules/compiler/src/java/flex2/compiler/mxml/dom/VectorNode.java
      modules/compiler/src/java/flex2/compiler/mxml/reflect/ElementTypeNotFound.java
      modules/compiler/src/java/flex2/compiler/mxml/rep/Vector.java
      modules/compiler/src/java/flex2/compiler/mxml/builder/VectorBuilder.java
      Initial checkin.
      modules/compiler/src/java/flex2/compiler/mxml/dom/SyntaxTreeBuilder.java
      Added parseVector()
      modules/compiler/src/java/flex2/compiler/mxml/dom/MxmlScanner.java
      Modified createNode() to handle ParserConstants.START_VECTOR case.
      modules/compiler/src/java/flex2/compiler/mxml/lang/ValueNodeHandler.java
      Modified isValueNode() and invoke() to handle VectorNode.
      modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      Added CLASS_VECTOR and PROP_TYPE.
      modules/compiler/src/java/flex2/compiler/mxml/lang/NodeTypeResolver.java
      Added vectorNode()
      modules/compiler/src/java/flex2/compiler/mxml/lang/TypeCompatibility.java
      Added OkCoerceToVector constant.
      Modified check() by renaming lvalueArrayElemType to
      lvalueElementType and added handling for vectorType.
      modules/compiler/src/java/flex2/compiler/mxml/reflect/Property.java
      Added getElementType() and removed getArrayElementType(), which
      was folded into getElementType().
      modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
      Added vectorType variable.
      Added getElementType() and removed getArrayElementType() from TypeHelper.
      modules/compiler/src/java/flex2/compiler/mxml/analyzer/SyntaxAnalyzer.java
      Added analyze(VectorNode.
      modules/compiler/src/java/flex2/compiler/mxml/rep/Array.java
      Made list and elementType protected, so Vector can subclass Array.
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.java
      Modified getDefinitionBody() and generateDefinitionBody() to
      handle Vector.
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/ArrayElementInitializer.java
      Implemented generateAssignExpr(), because it's now used by Vector.
      modules/compiler/src/java/flex2/compiler/mxml/rep/StatesModel.java
      Added try/catch for ElementTypeNotFound.
      modules/compiler/src/java/flex2/compiler/mxml/rep/decl/InitializedPropertyDeclaration.jav a
      Modified getTypeExpr() to handle Vector.
      modules/compiler/src/java/flex2/compiler/mxml/rep/DocumentInfo.java
      Added addVectorVarDecl().
      modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractBuilder.java
      Renamed arrayElementType to elementType.
      Added OkCoerceToVector support.
      modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
      modules/compiler/src/java/flex2/compiler/mxml/builder/ArrayBuilder.java
      Added vectorNode(VectorNode).
      modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
      Added parseVector() everywhere we were calling parseArray().
      modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      Modified registerVariable() to handle Vector.
      Added VectorTypeRequired compiler error.
      modules/compiler/src/java/flex2/compiler/mxml/MxmlVisitor.java
      Added parseVector().
      modules/compiler/src/java/flex2/compiler/util/Name.java
      modules/compiler/src/java/flex2/compiler/util/MultiName.java
      Added some asserts to catch problems earlier.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-19214
      Modified Paths:
      flex/sdk/trunk/frameworks/mxml-manifest.xml
      flex/sdk/trunk/frameworks/projects/framework/manifest.xml
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Method.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Variable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Method.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/NodeMagic.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/TypeTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Variable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlVisitor.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/SyntaxAnalyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AnonymousObjectGraph Builder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ArrayBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/RemoteObjectBuilder. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/Analyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/AnalyzerAdapter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/MxmlScanner.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/SyntaxTreeBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/NodeTypeResolver.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/TypeCompatibility.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/ValueNodeHandler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Property.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Array.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/DocumentInfo.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/StatesModel.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/decl/InitializedProperty Declaration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ArrayElementInitial izer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/MultiName.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Name.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/PrefixMapping.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/VectorBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/VectorNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/ElementTypeNotFound. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Vector.java
