0 Replies Latest reply on Mar 11, 2009 8:16 AM by (Darrell_Loverin)
    [svn:fx-trunk] 5234: Initial check-in for FxWindowedApplication.
    Level 1
      Revision: 5234
      Author: dloverin@adobe.com
      Date: 2009-03-11 09:16:21 -0700 (Wed, 11 Mar 2009)
      Log Message:
      The FlexChrome has been written. FxTitleBarSkin provides a different look depending on if you are running on a mac or other OS.
      QE Notes: Not ready for testing
      Doc Notes: None
      Bugs: none
      Reviewer: Ryan
      tests: checkintests
      Modified Paths:
      flex/sdk/trunk/development/eclipse/flex/airframework/.actionScriptProperties
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/build.xml
      flex/sdk/trunk/frameworks/projects/airframework/defaults.css
      flex/sdk/trunk/frameworks/projects/airframework/src/AIRFrameworkClasses.as
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/WindowedApplication.as
      Added Paths:
      flex/sdk/trunk/frameworks/projects/airframework/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/FxWindowedApplication.as
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/windowClasses/FxTitleBar.as
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxCloseButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxGripperSkin.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxMacCloseButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxMacMaximizeButtonSki n.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxMacMinimizeButtonSki n.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxMaximizeButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxMinimizeButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxRestoreButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxTitleBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxWindowedApplicationS kin.mxml
