0 Replies Latest reply on Mar 12, 2009 12:08 PM by (Jim_Murphy)
    [svn:fx-trunk] 5272: Bugs: sdk-19825, sdk-19824
    Level 1
      Revision: 5272
      Author: jimurphy@adobe.com
      Date: 2009-03-12 13:08:41 -0700 (Thu, 12 Mar 2009)
      Log Message:
      -integrated TLF build 391.
      -Removed textLayout_conversion.swc,textLayout_core.swc, textLayout_edit.swc and textLayout_textField.swc. These have been replaced with textLayout.swc
      -created new "in" directory tlf. This is where I will integrate the TLF rsls. These are now being pre-built for us
      -Removed call to build TLF.swc in frameworks/build.xml
      -Removed references to the removed TLF swc's in flex4/build.xml and wireframe/build.xml
      Bugs: sdk-15437 , sdk-19821
      -updated the packaged frameworks/build.xml to rebuild: flex4,wireframe,sparkskins and halo
      -fixed the airframework target so the frameworks/build.xml does not error out
      qa: yes. check that when rebuilding the swc's in the framework that they are built correctly
      checkintests: pass
      Ticket Links:
      http://bugs.adobe.com/jira/browse/sdk-19825
      http://bugs.adobe.com/jira/browse/sdk-19824
      http://bugs.adobe.com/jira/browse/sdk-15437
      http://bugs.adobe.com/jira/browse/sdk-19821
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/build.xml
      flex/sdk/trunk/frameworks/build_framework.xml
      flex/sdk/trunk/frameworks/libs/textLayout.swc
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/wireframe/build.xml
      Added Paths:
      flex/sdk/trunk/in/tlf/
      flex/sdk/trunk/in/tlf/textLayout_391.swf
      flex/sdk/trunk/in/tlf/textLayout_391.swz
      Removed Paths:
      flex/sdk/trunk/frameworks/libs/textLayout_conversion.swc
      flex/sdk/trunk/frameworks/libs/textLayout_core.swc
      flex/sdk/trunk/frameworks/libs/textLayout_edit.swc
      flex/sdk/trunk/frameworks/libs/textLayout_textField.swc
