0 Replies Latest reply on Mar 16, 2009 7:50 AM by (Jim_Murphy)
    [svn:fx-trunk] 5321: -remove textLayout_textField.swc because textLayout. swc should now contain the API from it
    Level 1
      Revision: 5321
      Author: jimurphy@adobe.com
      Date: 2009-03-16 08:50:51 -0700 (Mon, 16 Mar 2009)
      Log Message:
      -remove textLayout_textField.swc because textLayout.swc should now contain the API from it
      and updated the build scripts to reflect the removal
      -changing the name of the textlayout rsls. Removed the build number from the swf and swz so that they won't have to be removed from src each time we take a new build. Use tlf.properties to get the correct build number
      checkintests: pass
      qa: yes - need to make sure that textlayout.swc contains everything from the swc's that have been removed
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/libs/textLayout.swc
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/framework_textLayout/build.xml
      flex/sdk/trunk/frameworks/projects/wireframe/build.xml
      flex/sdk/trunk/in/tlf/tlf.properties
      Added Paths:
      flex/sdk/trunk/in/tlf/textLayout.swf
      flex/sdk/trunk/in/tlf/textLayout.swz
      Removed Paths:
      flex/sdk/trunk/frameworks/libs/textLayout_textField.swc
      flex/sdk/trunk/in/tlf/textLayout_391.swf
      flex/sdk/trunk/in/tlf/textLayout_391.swz
