0 Replies Latest reply on Apr 8, 2008 12:43 PM by (Jono_Spiro)
    [svn] 1149: compiler: removed flex2.compiler.common. ConfigurationException and moved its members to the superclass (flex2. compiler.config.ConfigurationException)
    Level 1
      Revision: 1149
      Author: jspiro@adobe.com
      Date: 2008-04-08 13:43:04 -0700 (Tue, 08 Apr 2008)
      Log Message:
      compiler: removed flex2.compiler.common.ConfigurationException and moved its members to the superclass (flex2.compiler.config.ConfigurationException)
      Bugs: n/a
      QA: No
      Doc: No
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/ConfigurationPathResolver. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/FontsConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/FramesConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/MxmlConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/NamespacesConfiguration.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_en. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ja. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ja.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDocConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CommandLineConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Optimizer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Tool.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ToolsConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ApplicationCompilerConf iguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LibraryCompilerConfigur ation.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LinkerConfiguration.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMUtil.java
      Removed Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/ConfigurationException.jav a
