0 Replies Latest reply on Mar 16, 2009 12:29 PM by (Darrell_Loverin)
    [svn:fx-trunk] 5331: FxApplication related API changes.
      Revision: 5331
      Author: dloverin@adobe.com
      Date: 2009-03-16 13:29:20 -0700 (Mon, 16 Mar 2009)
      Log Message:
      1. Rename ApplicationGlobals.application -> FlexGlobals.topLevelApplication
      2. Application.application will be deprecated. FlexGlobals.topLevelApplication will be the recommend alternative.
      3. Application.application will return null if the top-level application is not of type Application or a subclass of Application.
      4. Change the FxApplication.backgroundColor property from type Object to uint.
      QE Notes: None
      Doc Notes: None
      Bugs: sdk-19677
      Reviewer: Ryan
      tests: checkintests, Application mustella tests
      Ticket Links:
      http://bugs.adobe.com/jira/browse/sdk-19677
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/Window.as
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/WindowedApplication.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxApplication.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxRadioButtonGroup.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Alert.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Menu.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/RadioButtonGroup.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Application.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Glow.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/ResizeInstance. as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/BrowserManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/CursorManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/HistoryManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/LayoutManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/PopUpManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/ToolTipManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ActivatorSkin.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
      flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/ActivatorSkin.as
      flex/sdk/trunk/frameworks/projects/haloclassic/src/haloclassic/ActivatorSkin.as
      flex/sdk/trunk/frameworks/tests/checkinapp/ProductDetail.mxml
      flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/FrameworkSwcDependenc yRules.java
      Added Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexGlobals.as
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ApplicationGlobals.as
