0 Replies Latest reply on Apr 8, 2008 1:56 PM by (Paul_Reilly)
    [svn] 1150: More direct syntax tree generation work-in-progress.
      Revision: 1150
      Author: preilly@adobe.com
      Date: 2008-04-08 14:56:01 -0700 (Tue, 08 Apr 2008)
      Log Message:
      More direct syntax tree generation work-in-progress. FlexStore now
      compiles and runs with -generate-abstract-syntax-tree set to true, but
      we still parse AS in a few places, like data bindings and styles,
      where it isn't always necessary. The unnecessary cases will be
      removed in the future to maximize performance.
      Asserts have been added to the places that will need an implementation
      before the full compiler test suite will pass.
      checkintests Passed: YES
      Needs QA: Not yet
      Needs DOC: NO
      API Change: NO
      Code-level description of changes:
      compiler/as3/AbstractSyntaxTreeUtil.java
      Added generateAssignment(), generateIdentifier(),
      generateMetaData(), generateParameter(), generateTypeExpression(),
      generateVariable(), generateVariableNew(), and parse().
      Combined generateConstructorDefinition() and
      generateConstructorCommon() into generateConstructor().
      compiler/as3/binding/DataBindingExtension.java
      Modified generateClassDefinition() to call
      nodeFactory.StartClassDefs() to fix a downstream FlowAnalyzer null
      pointer exception.
      Removed generateParameter(), which was added to AbstractSyntaxTreeUtil.
      compiler/mxml/builder/AbstractDocumentBuilder.java
      Modified analyze(BindingNode) to call setFromBindingNode().
      compiler/mxml/rep/Model.java
      Added getSubInitializerIterator().
      compiler/mxml/rep/AtResource.java
      Added getValueExpression().
      compiler/mxml/rep/MxmlDocument.java
      Made getTopLevelInitializerIterator() public and added some
      additional generics usage.
      compiler/mxml/rep/Array.java
      Added getSubInitializerIterator() and some additional generics
      usage.
      compiler/mxml/rep/init/EffectInitializer.java
      Added generateAssignExpr().
      compiler/mxml/rep/init/ValueInitializer.java
      Added generateValueExpr(), generateInlineRValue(),
      generateDefinitionBody(), generateDefinitions(), and AST versions
      of addAssignExprs(), formatExpr(), asArrayLiteral(),
      asObjectLiteral(), asXmlLiteral(), and asXMLList().
      compiler/mxml/rep/init/Initializer.java
      Added generateValueExpr(), generateAssignExpr(), and
      generateDefinitions().
      compiler/mxml/rep/init/StyleInitializer.java
      compiler/mxml/rep/init/EventInitializer.java
      generateDefinitionBody(), and generateDefinitions().
      compiler/mxml/rep/init/NamedInitializer.java
      compiler/mxml/rep/init/VisualChildInitializer.java
      compiler/mxml/rep/init/ArrayElementInitializer.java
      compiler/mxml/rep/decl/InitializedPropertyDeclaration.java
      compiler/mxml/rep/MovieClip.java
      compiler/mxml/rep/BindingExpression.java
      Added isFromBindingNode variable and accessors.
      Created ensureHighestLevelModelDeclared() from common code.
      Added generateDestinationAssignment(),
      generateDestinationSetStyle(), and generateDestinationPathRoot().
      compiler/mxml/ImplementationCompiler.java
      Added short circuit to parse1() for the generate AST case.
      compiler/mxml/gen/ClassDefLib.vm
      Removed unnecessary variable declaration.
      compiler/mxml/ImplementationGenerator.java
      Added a truck load of new methods and implemented numerous
      previously stubbed out methods.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractDocumentBuil der.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Array.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/AtResource.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Model.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MovieClip.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/decl/InitializedProperty Declaration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ArrayElementInitial izer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/EffectInitializer.j ava
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/EventInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/Initializer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/NamedInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/StyleInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/VisualChildInitiali zer.java
