0 Replies Latest reply on Mar 17, 2009 9:59 AM by Peter Farland
    [svn:fx-3.x] 5348: Applying IBM JDK fixes made on 3.0.1.x to 3.x ( remembering that unlike trunk, the 3.x branches have asc. jar precompiled and checked in).
    Peter Farland Level 3
      Revision: 5348
      Author: pfarland@adobe.com
      Date: 2009-03-17 10:59:35 -0700 (Tue, 17 Mar 2009)
      Log Message:
      Applying IBM JDK fixes made on 3.0.1.x to 3.x (remembering that unlike trunk, the 3.x branches have asc.jar precompiled and checked in).
      Fixing SwcFile.equals() to compare its VirtualFile rather than comparing an instance's VirtualFile to a SwcFile instance. This worked in many scenarios on Sun's JDK as its HashMap.get() implementation has an optimization that tests entry.key == key before calling .equals(). IBM 1.6 HashMap.get() calls .equals() and thus runs into this error for many VirtualFile implementations (as they typically only consider entities equal if they are of the same type, and clearly InMemoryFile != SwcFile).
      Also adding a workaround in ASC for now to avoid an infinite cycle of Multinames put() -> checkDelegate() -> super.putAll() -> put(). I'll transfer SDK-18978 to an ASC bug for further investigation on IBM JDK to track down the root cause.
      Also fixing merge error noticed in macromedia.asc.util.Context that was necessary in order to compile asc.jar.
      QE: Yes, please retest.
      Doc: No
      Checkintests: Pass
      Reviewer: Paul, Erik
      Bugs:
      SDK-19971 - Nullpointer with IBM JDK 1.6
      SDK-18978 - Can't compile mxml app using IBM JDK 1.6.
      SDK-19972 - incremental compile with IBM JDK 1.6 gives null pointer
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-18978
      http://bugs.adobe.com/jira/browse/SDK-19971
      http://bugs.adobe.com/jira/browse/SDK-19972
      Modified Paths:
      flex/sdk/branches/3.x/lib/asc.jar
      flex/sdk/branches/3.x/modules/asc/src/java/macromedia/asc/util/Context.java
      flex/sdk/branches/3.x/modules/asc/src/java/macromedia/asc/util/Multinames.java
      flex/sdk/branches/3.x/modules/compiler/src/java/flex2/compiler/swc/SwcFile.java
