0 Replies Latest reply on Apr 8, 2008 2:22 PM by (Jono_Spiro)
    [svn] 1152: compiler: class renaming and opportunistic warning cleanup
    Level 1
      Revision: 1152
      Author: jspiro@adobe.com
      Date: 2008-04-08 15:22:04 -0700 (Tue, 08 Apr 2008)
      Log Message:
      * flex2.compiler.as3:Configuration to As3Configuration
      * flex2.compiler.mxml:Configuration to MxmlConfiguration
      * flex2.linker:Configuration to LinkerConfiguration
      Bugs: n/a
      QA: Soon!
      Doc: No
      Modified Paths:
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/NodeFactory.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/HTTPServiceAnalyzer .java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/RemoteObjectAnalyze r.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/SyntaxAnalyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/WebServiceAnalyzer. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractDocumentBuil der.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AnonymousObjectGraph Builder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ArrayBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/HTTPServiceBuilder.j ava
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/InlineComponentBuild er.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ModelBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/PrimitiveBuilder.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/RemoteObjectBuilder. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ServiceRequestBuilde r.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/WebServiceBuilder.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/XMLBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/XMLListBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/AnalyzerAdapter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/decl/InitializedProperty Declaration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/NamedInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcMovie.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/ConsoleLogger.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/ConsoleApplication.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/FlexMovie.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/SimpleMovie.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PostLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LinkerConfiguration.jav a
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/concrete/DModule.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/expression/ASTBuilder.java
      flex/sdk/trunk/modules/debugger/src/java/flash/util/URLEncoder.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/ExpressionContext.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/LocationCollection.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerConfiguration.java
      Removed Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/Configuration.java
