0 Replies Latest reply on Mar 18, 2009 7:03 AM by (Paul_Reilly)
    [svn:fx-trunk] 5386: * Fix for Flex Builder JUnit tests.
    Level 1
      Revision: 5386<br />Author:   preilly@adobe.com<br />Date:     2009-03-18 08:03:11 -0700 (Wed, 18 Mar 2009)<br /><br />Log Message:<br />-----------<br />* Fix for Flex Builder JUnit tests.<br /><br />tests Passed: checkintests, performance testsuite<br /><br />Needs QA: YES<br /><br />Needs DOC: NO<br /><br />API Change: NO<br /><br />Reviewer: Pete F.<br /><br />Code-level description of changes:<br /> <br />  compiler/CompilerAPI.java<br /><br />    Changed the deleted Map used in validateCompilationUnits() and<br />    some of it's helper methods from <String, Source> to <QName,<br />    Source>.  This allows us to track when a definition is deleted<br />    from one SWC in the library path and then added by another SWC in<br />    the library path.  All the definitions dependant on the definition<br />    need to be recompiled and we were missing this before.<br />    Specifically, the Flex Builder JUnit tests were switching from<br />    airglobal.swc to playerglobal.swc midstream.  As a result, we<br />    weren't recompiling classes that depended on<br />    flash.display.DisplayObjectContainer, because it looked like it<br />    hadn't been deleted.<br /><br />Modified Paths:<br />--------------<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
