0 Replies Latest reply on Mar 18, 2009 7:50 AM by (Paul_Reilly)
    [svn:fx-trunk] 5388: * Data binding bug fix for LCDS.
      Revision: 5388
      Author: preilly@adobe.com
      Date: 2009-03-18 08:50:03 -0700 (Wed, 18 Mar 2009)
      Log Message:
      tests Passed: checkintests, mxunit databinding
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-18764
      API Change: NO
      Reviewer: Carol
      Code-level description of changes:
      as3/binding/PropertyWatcher.java
      Modified shouldWriteSelf() to return true if any child watchers
      need to be written.
      mxml/builder/DocumentBuilder.java
      Modified analyze(BindingNode) to no longer set the property on the
      component. This was incorrectly assuming that the destination was
      a property. It could also be a property chain or an expression.
      I noticed this problem due to some recently asserts which were
      added to flex2.compiler.util.Name.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-18764
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/PropertyWatcher.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
