0 Replies Latest reply on Apr 8, 2008 3:15 PM by (Jono_Spiro)
    [svn] 1154: compiler: renaming flex2.tools:Compiler to Mxmlc
    Level 1
      Revision: 1154
      Author: jspiro@adobe.com
      Date: 2008-04-08 16:15:38 -0700 (Tue, 08 Apr 2008)
      Log Message:
      Bugs: n/a
      QA: Yes, please test all mxmlc entrypoints, such as mxmlc[.exe], ant tasks, etc. (I cannot think of any others, actually).
      Doc: No
      Modified Paths:
      flex/sdk/trunk/modules/antTasks/src/flex/ant/MxmlcTask.java
      flex/sdk/trunk/modules/compiler/build.xml
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationBuffer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CommandLineConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Optimizer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ApplicationCompiler.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LibraryCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMUtil.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
      Removed Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compiler.java
