0 Replies Latest reply on Mar 23, 2009 5:11 PM by Jason Szeto
    [svn:fx-3.x] 5505: Flex SDK Bug Fix
    Jason Szeto Level 3
      Revision: 5505
      Author: jszeto@adobe.com
      Date: 2009-03-23 18:11:18 -0700 (Mon, 23 Mar 2009)
      Log Message:
      Flex SDK Bug Fix
      SDK-19410 - Slider does not issue change event when initial value is NaN
      Patch Submission from Jim Cheng:
      "The existing code would not dispatch a change event if the old value was a NaN in any case or if the difference between the old and newly modifed value was very small. I modified the logic to split the conditional into two parts, with an additional check to ensure that a change event is dispatched if the value is being changed from NaN to a valid number."
      QE Notes: n/a
      Doc Notes: n/a
      Bugs: SDK-19410
      Reviewer: Jason
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-19410
      Modified Paths:
      flex/sdk/branches/3.x/frameworks/projects/framework/src/mx/controls/sliderClasses/Slider. as
