0 Replies Latest reply on Mar 25, 2009 11:00 AM by (Jim_Murphy)
    [svn:fx-trunk] 5545: 1st pass of rename according to the spec http:// opensource.adobe.com/wiki/display/flexsdk/Dropping+the+Fx+Prefix
    Level 1
      Revision: 5545
      Author: jimurphy@adobe.com
      Date: 2009-03-25 12:00:52 -0700 (Wed, 25 Mar 2009)
      Log Message:
      1st pass of rename according to the spec http://opensource.adobe.com/wiki/display/flexsdk/Dropping+the+Fx+Prefix
      Flex now requires CSS Style declarations to declare @namespace rules and disambiguate between halo and spark components using CSS 3 namespace prefixes on type selectors. At compile time, this namespace information will be used to map type names to qualified ActionScript class names. At runtime, type selectors are matched on qualified ActionScript class name (for example mx.controls.Button rather than just Button). Flex 3 applications must be compiled with -compatibility-version=3.0.0 to get unqualified CSS type selector behavior.
      QE: Yes, this build may help in updating test cases to use the new namespaces and class names.
      Dev: Not yet
      Doc: Not yet
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/development/eclipse/flex/flex4/.actionScriptProperties
      flex/sdk/trunk/development/eclipse/flex/flex4/.flexLibProperties
      flex/sdk/trunk/development/eclipse/flex/flex4test/.actionScriptProperties
      flex/sdk/trunk/development/eclipse/flex/flex4test/.flexProperties
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/AddItemsTest.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/EffectsProperties.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/NewEffects.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/RemoveItemsTest.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/ScrollbarFrenzy.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/SkinTest.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/components/AnimationPropertiesForm. mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/components/CircularScrollBar.as
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/flex4test.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/layouts/NumberInterpolatorWrapping. as
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/layouts/WheelLayout.as
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/skins/CircularScrollBarSkin.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/skins/CircularScrollBarTrackSkin.mx ml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/skins/MyScrollBarTrackSkin.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/skins/MyVScrollBarSkin.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/testWheel.mxml
      flex/sdk/trunk/development/eclipse/flex/framework/.actionScriptProperties
      flex/sdk/trunk/development/eclipse/flex/framework/.flexLibProperties
      flex/sdk/trunk/development/eclipse/flex/rpc/.actionScriptProperties
      flex/sdk/trunk/development/eclipse/flex/rpc/.flexLibProperties
      flex/sdk/trunk/frameworks/flex-config.xml
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/build.xml
      flex/sdk/trunk/frameworks/projects/airframework/defaults.css
      flex/sdk/trunk/frameworks/projects/airframework/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/src/AIRFrameworkClasses.as
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/windowClasses/FxTitleBar.as
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/DataGroupExam ple.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/FxButtonExamp le.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/FxCheckBoxExa mple.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/FxHSliderExam ple.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/FxListExample .mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/FxNumericStep perExample.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/FxSpinnerExam ple.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/FxTextAreaExa mple.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/FxTextInputEx ample.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/FxToggleButto nExample.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/FxVSliderExam ple.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/GroupExample. mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/components/examples/TextViewExamp le.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/effects/FxAnimateEffectExample.mx ml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/effects/examples/FxAnimateColorEf fectExample.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/effects/examples/FxAnimateEffectE xample.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/effects/examples/FxAnimateShaderT ransitionExample.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/effects/examples/FxCrossFadeExamp le.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/effects/examples/FxFadeEffectExam ple.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/effects/examples/FxMoveEffectExam ple.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/effects/examples/FxResizeEffectEx ample.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/effects/examples/FxRotateEffectEx ample.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/effects/examples/FxWipeExample.mx ml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/graphics/examples/ArrowExample.mx ml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/graphics/examples/BitmapGraphicEx ample.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/graphics/examples/CircleExample.m xml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/graphics/examples/EllipseExample. mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/graphics/examples/LineExample.mxm l
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/graphics/examples/RectExample.mxm l
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/graphics/examples/TextBoxExample. mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/graphics/examples/TextGraphicExam ple.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/styles/examples/DateStateComp.mxm l
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/styles/examples/DescendantSelecto rExample.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/styles/examples/IDSelectorExample .mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/styles/examples/PseudoSelectorExa mple.mxml
      flex/sdk/trunk/frameworks/projects/flex4/asdoc/en_US/mx/styles/examples/TypeClassSelector Example.mxml
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/defaults.css
      flex/sdk/trunk/frameworks/projects/flex4/manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/Flex4Classes.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransform.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformMove.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformMove3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformRotate.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformRotate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformScale.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformScale3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/KeyFrame.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/MotionPath.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/effectClasses/AnimateTransform Instance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/MetadataEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/VideoEvent.as
      flex/sdk/trunk/frameworks/projects/framework/build.xml
      flex/sdk/trunk/frameworks/projects/framework/defaults.css
      flex/sdk/trunk/frameworks/projects/framework/manifest.xml
      flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
      flex/sdk/trunk/frameworks/projects/rpc/build.xml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/AccordionHeaderSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/BorderSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarFirstButtonSkin .mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarLastButtonSkin. mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarMiddleButtonSki n.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/CheckBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ColorPickerSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ComboBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DataGridHeaderBackground Skin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DataGridHeaderSeparatorS kin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserNextMonthSkin .mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserNextYearSkin. mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserPrevMonthSkin .mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserPrevYearSkin. mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserRollOverIndic atorSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserSelectionIndi catorSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserTodayIndicato rSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DefaultButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/EditableComboBoxSkin.mxm l
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/LinkButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/MenuItemSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/MenuSeparatorSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/PanelBorderSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/PopUpButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ProgressBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ProgressBarTrackSkin.mxm l
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/RadioButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarDownButtonSkin. mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarUpButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/SliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/SliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperDecrButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperIncrButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/TabSkin.mxml
      flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/TextInputBorderSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/WireframeClasses.as
      flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleRule.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/CssCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MXMLNamespaces.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/MxmlScanner.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/WebTierAPI.java
      Added Paths:
      flex/sdk/trunk/frameworks/halo-manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/defaults-3.0.0.css
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/windowClasses/
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/windowClasses/TitleB ar.as
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/windowClasses/Window edApplication.as
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/CloseButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/GripperSkin.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/MacCloseButtonSki n.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/MacMaximizeButton Skin.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/MacMinimizeButton Skin.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/MaximizeButtonSki n.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/MinimizeButtonSki n.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/RestoreButtonSkin .mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/TitleBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/default/WindowedApplicati onSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/defaults-3.0.0.css
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Application.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Button.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Button.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/ButtonBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/ButtonBar.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/ButtonBarButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/CheckBox.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/CheckBox.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/DataGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/DataGroup.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/DropDownList.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Group.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/HGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/HGroup.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/HScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/HScrollBar.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/HSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/HSlider.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/IItemRenderer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/IItemRendererOwner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/List.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/List.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/MXMLComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/NumericStepper.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/NumericStepper.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Panel.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Panel.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/PopUp.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/RadioButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/RadioButton.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/RadioButtonGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/RadioButtonGroup.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/ResizeMode.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/RichEditableText.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/RichEditableText.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Scroller.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Scroller.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/SkinnableContainer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/SkinnableContainer.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/SkinnableDataContainer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/SkinnableDataContainer.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Spinner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Spinner.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/TextArea.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/TextArea.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/TextInput.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/TextInput.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/TextSelectionVisibility.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/ToggleButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/ToggleButton.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VGroup.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VScrollBar.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VSlider.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoDisplay.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoDisplay.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ButtonBase.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/DropDownBase .as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/GroupBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/Invalidating Sprite.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ItemRenderer .as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ListBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/Range.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ScrollerLayo ut.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/Skin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/SkinnableCom ponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/SkinnableCon tainerBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/Slider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/TextBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ToggleButton Base.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/TrackBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/windowClasses/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/IDeferredContentOwner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/IGraphicElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/ISharedDisplayObject.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/IViewport.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/MaskType.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/ScrollUnit.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/SpriteVisualElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/Version.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AddAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Animate.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Animate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateColor.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateShaderTransition.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimationProperty.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/CallAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/CrossFade.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/CrossFade.pbj
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/CrossFade.pbk
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Fade.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Move.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/RemoveAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Resize.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Rotate.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Rotate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/SetAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Wipe.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Wipe.pbj
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Wipe.pbk
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/WipeDirection.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/Animation.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/Timeline.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/easing/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/easing/EaseInOut.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/easing/IEaser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/easing/Linear.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/easing/Power.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/easing/Sine.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/ArrayInterpolato r.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/HSBInterpolator. as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/IInterpolator.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/NumberArrayInter polator.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/NumberInterpolat or.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/RGBInterpolator. as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AddActionInstan ce.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/Animate3DInstan ce.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateColorIns tance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateFilterIn stance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateInstance .as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateShaderTr ansitionInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/CallActionInsta nce.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/FadeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/MoveInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/RemoveActionIns tance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/ResizeInstance. as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/Rotate3DInstanc e.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/RotateInstance. as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/SetActionInstan ce.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/WipeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/AnimationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/ElementExistenceEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/RendererExistenceEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/TextOperationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/BevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/BlurFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/ColorMatrixFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/ConvolutionFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/DisplacementMapFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/DropShadowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/GlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/GradientBevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/GradientFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/GradientGlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/filters/ShaderFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/BasicLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/HorizontalAlign.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/HorizontalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/TileJustifyColumns.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/TileJustifyRows.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/TileLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/TileOrientation.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/VerticalAlign.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/VerticalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/supportClasses/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/supportClasses/Block.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/supportClasses/LayoutBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/supportClasses/LayoutElementFac tory.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/supportClasses/LayoutElementHel per.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/layout/supportClasses/LinearLayoutVect or.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/BitmapImage.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/BitmapImageResizeMode.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Ellipse.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Graphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Line.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Path.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Rect.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/RichText.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/RichText.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/SimpleText.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/SimpleText.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/VideoElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/VideoElement.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/pathSegments/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/pathSegments/CloseSegment.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/pathSegments/CubicBezierSeg ment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/pathSegments/LineSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/pathSegments/MoveSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/pathSegments/PathSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/pathSegments/QuadraticBezie rSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/FilledElemen t.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/GraphicEleme nt.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/ISharedGraph icsDisplayObject.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/StrokedEleme nt.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/TextGraphicE lement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/SparkSkin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ApplicationSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ButtonBarFirstButtonSkin .mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ButtonBarLastButtonSkin. mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ButtonBarMiddleButtonSki n.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ButtonBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/CheckBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/DefaultButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/DefaultComplexItemRender er.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/DefaultItemRenderer.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/DropDownListButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/DropDownListSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/FocusSkin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/HScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/HScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/HScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/HSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/HSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/HSliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ListSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/NumericStepperSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/NumericStepperTextInputS kin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/PanelSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/RadioButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ScrollBarDownButtonSkin. mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ScrollBarLeftButtonSkin. mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ScrollBarRightButtonSkin .mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ScrollBarUpButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ScrollerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/SkinnableContainerSkin.m xml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/SkinnableDataContainerSk in.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/SpinnerDecrButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/SpinnerIncrButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/SpinnerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/TextAreaSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/TextInputSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ToggleButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VSliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoDisplayMuteButtonSk in.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoDisplayPlayPauseBut tonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoDisplaySkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/styles/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/styles/metadata/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/styles/metadata/AdvancedTextLayoutForm atStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/styles/metadata/BasicTextLayoutFormatS tyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/styles/metadata/NonInheritingTextLayou tFormatStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/styles/metadata/SelectionFormatTextSty les.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/styles/metadata/SparkColorStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/utils/
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/utils/LabelUtil.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/utils/MouseShieldUtil.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/utils/TextUtil.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/states/AddItems.as
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/CheckBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/DefaultComplexItem Renderer.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/DefaultItemRendere r.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HScrollBarSkin.mxm l
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HScrollBarThumbSki n.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HScrollBarTrackSki n.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HSliderThumbSkin.m xml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HSliderTrackSkin.m xml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ListSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/NumericStepperSkin .mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/NumericStepperText InputSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/RadioButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ScrollBarDownButto nSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ScrollBarLeftButto nSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ScrollBarRightButt onSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ScrollBarUpButtonS kin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/SpinnerDecrButtonS kin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/SpinnerIncrButtonS kin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/SpinnerSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TextAreaSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TextInputSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ToggleButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VScrollBarSkin.mxm l
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VScrollBarThumbSki n.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VScrollBarTrackSki n.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VSliderThumbSkin.m xml
      flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VSliderTrackSkin.m xml
      flex/sdk/trunk/frameworks/spark-manifest.xml
      flex/sdk/trunk/frameworks/tests/componentSmoke/componentSmoke2-config.xml
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/FxWindowedApplication.as
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxCloseButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxGripperSkin.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxMacCloseButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxMacMaximizeButtonSki n.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxMacMinimizeButtonSki n.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxMaximizeButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxMinimizeButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxRestoreButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxTitleBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/spark/FxWindowedApplicationS kin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/ButtonBarButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/DataGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/DataGroup.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/DropDownList.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxApplication.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxButton.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxButtonBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxButtonBar.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxCheckBox.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxCheckBox.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxContainer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxContainer.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxDataContainer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxDataContainer.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxHScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxHScrollBar.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxHSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxHSlider.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxList.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxList.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxNumericStepper.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxNumericStepper.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxPanel.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxPanel.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxRadioButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxRadioButton.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxRadioButtonGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxRadioButtonGroup.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxScroller.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxScroller.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxScrollerLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxSpinner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxSpinner.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxTextArea.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxTextArea.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxTextInput.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxTextInput.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxToggleButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxToggleButton.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxVScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxVScrollBar.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxVSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxVSlider.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxVideoDisplay.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxVideoDisplay.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/Group.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/HGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/HGroup.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/IItemRenderer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/IItemRendererOwner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/ItemRenderer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/MXMLComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/PopUp.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/ResizeMode.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/Skin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/TextSelectionVisibility.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/TextView.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/TextView.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/VGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/VGroup.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/ButtonBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/DropDownBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxContainerBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxListBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxRange.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxTextBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxTrackBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/GroupBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/ToggleButtonBase.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/core/IDeferredContentOwner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/core/IViewport.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/core/InvalidatingSprite.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/core/ScrollUnit.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/core/SpriteVisualElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/core/Version.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/AddAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/Animation.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/AnimationProperty.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/CallAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimate.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimateColor.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimateFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimateShaderTransition.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxCrossFade.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxCrossFade.pbj
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxCrossFade.pbk
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxFade.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxMove.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxResize.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxRotate.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxRotate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxWipe.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxWipe.pbj
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxWipe.pbk
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/PropertyValuesHolder.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/RemoveAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/SetAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/Timeline.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/WipeDirection.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/AddActionInstance.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/CallActionInstance. as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimate3DInstance .as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateColorInsta nce.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateFilterInst ance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateInstance.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateShaderTran sitionInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxFadeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxMoveInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxResizeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxRotate3DInstance. as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxRotateInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxWipeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/RemoveActionInstanc e.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/SetActionInstance.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/ArrayInterpolator.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/EaseInOut.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/HSBInterpolator.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/IEaser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/IInterpolator.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/Linear.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/NumberArrayInterpol ator.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/NumberInterpolator. as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/Power.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/RGBInterpolator.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/Sine.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/events/AnimationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/events/ElementExistenceEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/events/RendererExistenceEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/events/TextOperationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/BevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/BlurFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/ColorMatrixFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/ConvolutionFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/DisplacementMapFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/DropShadowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GradientBevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GradientFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GradientGlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/ShaderFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/BitmapGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/BitmapResizeMode.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/CloseSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/CubicBezierSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Ellipse.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/FilledElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Graphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/IGraphicElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/ISharedDisplayObject.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Line.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/LineSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/MaskType.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/MoveSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Parser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Path.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/PathSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/QuadraticBezierSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Rect.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/StrokedElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/TextBox.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/TextBox.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/TextGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/TextGraphic.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/VideoElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/VideoElement.png
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/baseClasses/GraphicElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/baseClasses/ISharedGraphicsDispl ayObject.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/baseClasses/TextGraphicElement.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/BasicLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/Block.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/HorizontalAlign.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/HorizontalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutElementFactory.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutElementHelper.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LinearLayoutVector.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/TileJustifyColumns.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/TileJustifyRows.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/TileLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/TileOrientation.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/VerticalAlign.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/VerticalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/DropDownListButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/DropDownListSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxApplicationSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarFirstButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarLastButtonSkin.mxm l
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarMiddleButtonSkin.m xml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxCheckBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxContainerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxDataContainerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxDefaultButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxDefaultComplexItemRenderer. mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxDefaultItemRenderer.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxFocusSkin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHSliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxListSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxNumericStepperSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxNumericStepperTextInputSkin .mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxPanelSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxRadioButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarDownButtonSkin.mxm l
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarLeftButtonSkin.mxm l
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarRightButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarUpButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxSpinnerDecrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxSpinnerIncrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxSpinnerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxTextAreaSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxTextInputSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxToggleButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVSliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVideoDisplayMuteButtonSkin. mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVideoDisplayPlayPauseButton Skin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVideoDisplaySkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/SparkSkin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/states/AddItems.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/AdvancedTextLayoutFormatS tyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/BasicTextLayoutFormatStyl es.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/NonInheritingTextLayoutFo rmatStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/SelectionFormatTextStyles .as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/SparkColorStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/utils/LabelUtil.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/utils/MouseShieldUtil.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/utils/TextUtil.as
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxCheckBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxDefaultComplexItemRenderer.m xml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxDefaultItemRenderer.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHSliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxListSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxNumericStepperSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxNumericStepperTextInputSkin. mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxRadioButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxScrollBarDownButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxScrollBarLeftButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxScrollBarRightButtonSkin.mxm l
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxScrollBarUpButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxSpinnerDecrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxSpinnerIncrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxSpinnerSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxTextAreaSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxTextInputSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxToggleButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVSliderTrackSkin.mxml
