0 Replies Latest reply on Mar 25, 2009 1:50 PM by Peter Farland
    [svn:fx-trunk] 5558: Add hack to Grammar. jj to allow special component tags in spark and halo namespaces to resolve to special node in the parser .
    Peter Farland Level 3
      Revision: 5558
      Author: pfarland@adobe.com
      Date: 2009-03-25 14:50:18 -0700 (Wed, 25 Mar 2009)
      Log Message:
      Add hack to Grammar.jj to allow special component tags in spark and halo namespaces to resolve to special node in the parser. This will be re-addressed once we stabilize on the renames and can better enforce the contents of MXML 2006, MXML 2009, FXG, Spark and Halo.
      Add a work around for the step building the AIR Updater UI to set -compatibility-version=3.0.0. This involved checking in a local copy to override the sample-frameworks-build.xml checked into the AIR Integration Kit.zip.
      Adding missing base halo and spark classes that appear as qualified type selectors in our defaults.css files but have historically not been in our manifests for MXML tag mappings.
      QE: This should help pass more tests.
      Dev: Not yet
      Doc: Not yet
      Modified Paths:
      flex/sdk/trunk/frameworks/build.xml
      flex/sdk/trunk/frameworks/halo-manifest.xml
      flex/sdk/trunk/frameworks/spark-manifest.xml
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MXMLNamespaces.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/MxmlScanner.java
      Added Paths:
      flex/sdk/trunk/in/air/sample-frameworks-build.xml
