0 Replies Latest reply on Mar 25, 2009 4:55 PM by Peter Farland
    [svn:fx-trunk] 5561: Fixing compatibility-version= 3 mode as it seems there are two ways in StylesContainer that look for dependencies against type selectors , one path is for developer specified styles, the other is for default styles.
    Peter Farland Level 3
      Revision: 5561
      Author: pfarland@adobe.com
      Date: 2009-03-25 17:55:30 -0700 (Wed, 25 Mar 2009)
      Log Message:
      Fixing compatibility-version=3 mode as it seems there are two ways in StylesContainer that look for dependencies against type selectors, one path is for developer specified styles, the other is for default styles.
      Setting compatibility mode to 3 for checkinapp.
      Also removing minor debug output left in build.xml for component smokes ant target.
      QE: This too will help if you're relying on compatibility mode to compile MXML 2006 apps after the rename.
      Dev: Not yet
      Doc: No
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
      Added Paths:
      flex/sdk/trunk/frameworks/tests/checkinapp/checkinapp-config.xml
