0 Replies Latest reply on Mar 27, 2009 5:59 AM by Peter Farland
    [svn:fx-trunk] 5647: Fixing programmatic usages of 'mx.components' to the spark equivalent after the rename.
    Peter Farland Level 3
      Revision: 5647
      Author: pfarland@adobe.com
      Date: 2009-03-27 06:59:54 -0700 (Fri, 27 Mar 2009)
      Log Message:
      Also fixing calls to StyleManager.getStyleDeclaration() that use an unqualified type name. Type selectors should be referenced via fully qualified ActionScript class names at runtime. When compatibility version is set to 3, getStyleDeclaration will remove the package name to match type selectors in the legacy unqualified manner.
      QE: This fixes bug SDK-20253, and potentially a few other edge cases like the CursorManager RTE.
      Doc: No
      Checkintests: Pass
      Bugs:
      SDK-20253 - [rename_work] Spark RadioButton and CheckBox focus ring now highlights the label of the RadioButton
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-20253
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/NativeDragManagerImpl.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Scroller.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/FocusSkin.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/CursorManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/DragManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/printing/FlexPrintJob.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/BusyCursor.as
      flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/BusyCursor.as
      flex/sdk/trunk/frameworks/projects/haloclassic/src/haloclassic/BusyCursor.as
