0 Replies Latest reply on Mar 30, 2009 7:46 AM by (Jim_Murphy)
    [svn:fx-trunk] 5747: -The manifests for framework and flex4 will now be maintained from the frameworks /halo-manifest.xml and frameworks/spark-manifest. xml instead of maintaining duplicate copies.
    Level 1
      Revision: 5747
      Author: jimurphy@adobe.com
      Date: 2009-03-30 08:46:03 -0700 (Mon, 30 Mar 2009)
      Log Message:
      -The manifests for framework and flex4 will now be maintained from the frameworks/halo-manifest.xml and frameworks/spark-manifest.xml instead of maintaining duplicate copies.
      -edited halo-manifest.xml:
      -added back the flash.filters classes
      -added lookupOnly="true" for classes that refer to other swcs
      -removed mxml-2009-manifest.xml
      -mxml-manifest.xml is removed from SVN but is now copied (during the build) from halo-manifest.xml and will still remain in the frameworks directory just not under src.
      -renamed the airframework manifest files to be more air specific
      -removed bundles.properties as they should not be checked in because they are created during the build.xml
      -update flex/flex4/.project to have the spark-manifest link to point at frameworks/spark-manifest.xml
      qa: yes. there may be an issue using the flash.filters when using multiple namespaces
      doc: no
      tests: checkintests pass
      Ticket Links:
      http://bugs.adobe.com/jira/browse/mxml-2009
      Modified Paths:
      flex/sdk/trunk/development/eclipse/flex/airframework/.actionScriptProperties
      flex/sdk/trunk/development/eclipse/flex/airframework/.flexLibProperties
      flex/sdk/trunk/development/eclipse/flex/flex4/.project
      flex/sdk/trunk/frameworks/air-config.xml
      flex/sdk/trunk/frameworks/build.xml
      flex/sdk/trunk/frameworks/flex-config.xml
      flex/sdk/trunk/frameworks/halo-manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/build.xml
      flex/sdk/trunk/frameworks/spark-manifest.xml
      Added Paths:
      flex/sdk/trunk/frameworks/projects/airframework/halo-air-manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/spark-air-manifest.xml
      Removed Paths:
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/mxml-manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/manifest.xml
      flex/sdk/trunk/frameworks/projects/framework/manifest.xml
      flex/sdk/trunk/frameworks/projects/halo/bundles.properties
      flex/sdk/trunk/frameworks/projects/sparkskins/bundles.properties
