0 Replies Latest reply on Mar 30, 2009 9:38 AM by (Jim_Murphy)
    [svn:fx-trunk] 5757: Merged i11 revisions 5489,5524,5537 -> trunk
    Level 1
      Revision: 5757
      Author: jimurphy@adobe.com
      Date: 2009-03-30 10:38:57 -0700 (Mon, 30 Mar 2009)
      Log Message:
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/GroupBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Animate3D.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilationUnit.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/PersistenceStore.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/AbcCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedSkinClassEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/HostComponentEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/StyleEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableExtension.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ASDocExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcGroup.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcScript.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/CULinkable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/ConsoleApplication.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMReport.java
      Property Changed:
      flex/sdk/trunk/
