0 Replies Latest reply on Apr 9, 2008 1:30 PM by (Jono_Spiro)
    [svn] 1168: compiler: renaming the API classes
    Level 1
      Revision: 1168
      Author: jspiro@adobe.com
      Date: 2008-04-09 14:30:32 -0700 (Wed, 09 Apr 2008)
      Log Message:
      * flex2.compiler.asdoc:API to AsDocAPI
      * flex2.compiler.swc:API to SwcAPI
      * flex2.compiler:API to CompilerAPI
      * flex2.linker:API to LinkerAPI
      * flex2.tools:API to WebTierAPI
      Bugs: n/a
      QA: Yes, we should probably run the suite on this; though we could also wait for the Compiler classes to get renamed
      Doc: No
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SourcePath.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/TypeAnalyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeClassInfo.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlLogAdapter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ja.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_en.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_ja.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDocConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CommandLineConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcPreLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Optimizer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Toolkit.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ApplicationCompilerConf iguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LibraryCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMUtil.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/WebTierAPI.java
      Removed Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/API.java
