0 Replies Latest reply on Mar 31, 2009 10:34 AM by Chet Haase
    [svn:fx-trunk] 5812: Fixed a bug where direct use of Animation failed because AnimationProperty was not setting up its internal keyframes with correct duration information , so the animation would skip immediately to the end.
    Chet Haase
      Revision: 5812
      Author: chaase@adobe.com
      Date: 2009-03-31 11:34:56 -0700 (Tue, 31 Mar 2009)
      Log Message:
      Fixed a bug where direct use of Animation failed because AnimationProperty was not setting up its internal keyframes with correct duration information, so the animation would skip immediately to the end.
      Bugs: SDK-20356
      QE Notes: spark/effects Mustella tests currently hosed, couldn't run test suite
      Doc Notes: None
      Reviewer: Jason
      Testing: checkintests, Mustella effects tests could not be run (post-rename issues)
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-20356
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimationProperty.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/Animation.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateColorIns tance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateShaderTr ansitionInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/FadeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/MoveInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/ResizeInstance. as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/Rotate3DInstanc e.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/RotateInstance. as
