3 Replies Latest reply on Jun 13, 2006 7:32 AM by CathyM
    FDS, Tomcat, JOTM and Beta3
    kevinykim
      I have a Flex app that uses JMS deployed on Tomcat.
      This app worked under Beta2. I upgraded to Beta3, and installed JOTM on Tomcat.
      I can't figure out how to configure the app correctly. Based on the log (debug level),
      it doesn't even seem to be attempting to connect to my JMS.
      Originally, I had the following in my app/WEB-INF/flex/flex-message-service.xml:
      <destination id="chat-topic-jms">
      <properties>
      <server>
      <durable>false</durable>
      <durable-store-manager>flex.messaging.durability.FileStoreManager</durable-store-manager>
      </server>
      <jms>
      <destination-type>Topic</destination-type>
      <message-type>javax.jms.TextMessage</message-type>
      <connection-factory>MessagingTopic</connection-factory>
      <destination-jndi-name>GlobalEvents</destination-jndi-name>
      <durable-consumers>false</durable-consumers>
      <delivery-mode>NON_PERSISTENT</delivery-mode>
      <message-priority>DEFAULT_PRIORITY</message-priority>
      <acknowledge-mode>AUTO_ACKNOWLEDGE</acknowledge-mode>
      <transacted-sessions>false</transacted-sessions>
      <initial-context-environment>
      <property>
      <name>java.naming.factory.initial</name>
      <value>com.sonicsw.jndi.mfcontext.MFContextFactory</value>
      </property>
      <property>
      <name>com.sonicsw.jndi.mfcontext.domain</name>
      <value>Domain1</value>
      </property>
      <property>
      <name>java.naming.provider.url</name>
      <value>tcp://jmsserver:2506</value>
      </property>
      <property>
      <name>java.naming.security.principle</name>
      <value>jms_user</value>
      </property>
      <property>
      <name>java.naming.security.credentials</name>
      <value>jms_pass</value>
      </property>
      </initial-context-environment>
      </jms>
      </properties>
      <channels>
      <channel ref="my-rtmp"/>
      </channels>
      <adapter ref="jms"/>
      </destination>
      As near as I can figure, I need to modify $TOMCAT_HOME/conf/Catalina/localhost/app.xml
      to this:
      <?xml version="1.0" encoding="utf-8" ?>
      <Context displayName="Flex Enterprise Services"
      path="/app"
      docBase="<tomcathome>/webapps/app"
      workDir="work/Catalina/localhost/app">
      <!-- Description of the resource "UserTransaction" -->
      <Resource name="UserTransaction"
      auth="Container"
      type="javax.transaction.UserTransaction" />
      <ResourceParams name="UserTransaction">
      <parameter>
      <name>factory</name>
      <value>org.objectweb.jotm.UserTransactionFactory</value>
      </parameter>
      <parameter>
      <name>jotm.timeout</name>
      <value>60</value>
      </parameter>
      </ResourceParams>
      <Resource name="GlobalEvents"
      auth="Container"
      type="javax.jms.TextMessage"
      factory="TopicConnectionFactory"
      physicalName="chat-topic-jms" />
      </Context>
      As near as I can tell, the app isn't even trying to connect to the JMS.
      Can anyone provide a clue to what I've missed?
      -kevin
        • 1. Re: FDS, Tomcat, JOTM and Beta3
          CathyM Level 1
          In flex-enterprise-services.xml, enable logging and the debug level and check your server console for errors.
          Another thing that might be helpful is ensure that you can reach the destinations via jndi.
          You can do this by using a jsp page. If the page runs without stack traces, then you know that your jndi and jms factory and destination are configured correctly. Be sure to update flex-message-service.xml with those jndi names.
          jndiTest.jsp
          <%@ page import="javax.naming.*,javax.util.*" %>
          Properties p = new Properties();
          // as configured in your destination's initial-context-environment in flex-message-service.xml
          p.setProperty("java.naming.factory.initial","com.sonicsw.jndi.mfcontext.MFContextFactory" );
          p.setProperty("com.sonicsw.jndi.mfcontext.domain","Domain1");
          p.setProperty("java.naming.provider.url","tcp://jmsserver:2506");
          p.setProperty("java.naming.security.principle","jms_user");
          p.setProperty("java.naming.security.credentials","jms_pass");
          Context ctx = new InitialContext(p);
          ctx.lookup("MessagingTopic"); // this maps to connection-factory on the destination in flex-message-service.xml
          ctx.lookup("GlobalEvents"); // this maps to destination-jndi-name on the destination in flex-message-service.xml
          /* If you get an exception running with the above try, generally application servers make resource available to the application at java:comp/env/<resource-name>. In the app.xml, you've specified GlobalEvents as the resource name. I don't see MessageTopic specified in app.xml, which may be an issue. Once you have these lookup calls running, you should go back and update flex-message-service.xml with these jndi names.
          ctx.lookup("java:comp/env/GlobalEvents");
          ctx.lookup("java:comp/env/MessageTopic");
          • 2. Re: FDS, Tomcat, JOTM and Beta3
            kevinykim Level 1
            I had the logging set to "debug" and turned on, but saw nothing.
            Back in Beta2, I use to get a lot messages about trying to connect to the JMS.
            Well, the JSP worked fine (after I changed the "javax.util.*" to "java.util.*).
            So I assume my connection is good.
            You mentioned putting MessageTopic in the app.xml, any hints on how it should look?
            -kevin
            • 3. Re: FDS, Tomcat, JOTM and Beta3
              CathyM Level 1
              You'll need to reference the instructions for integrating your JMS server with Tomcat. If the jsp page works, it's likely that you topics and connection factories are set up correctly.
              You should be seeing the incoming rtmp messages logged to your server console.
              If you're not seeing any messages on the server console, then something is wrong with your configuration.
              Check that the destination name you're using in your mxml application matches the destination defined in flex-message-service.xml.
