0 Replies Latest reply on Apr 9, 2008 3:17 PM by (Jono_Spiro)
    [svn] 1170: compiler: renaming the Compiler classes
    Level 1
      Revision: 1170
      Author: jspiro@adobe.com
      Date: 2008-04-09 16:17:57 -0700 (Wed, 09 Apr 2008)
      Log Message:
      * flex2.compiler.abc:Compiler to AbcCompiler
      * flex2.compiler.as3:Compiler to As3Compiler
      * flex2.compiler.css:Compiler to CssCompiler
      * flex2.compiler.i18n:Compiler to I18nCompiler
      * flex2.compiler.mxml:Compiler to MxmlCompiler
      Bugs: n/a
      QA: Yes
      Doc: No
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/MetaDataParser.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeSecondPassEv aluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ja.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/WebTierAPI.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/AbcCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/CssCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/I18nCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlCompiler.java
      Removed Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Compiler.java
