0 Replies Latest reply on Apr 1, 2009 9:34 AM by (Paul_Reilly)
    [svn:fx-trunk] 5839: * Removed the logic that tracked when cached SWC had been removed from
    Level 1
      Revision: 5839
      Author: preilly@adobe.com
      Date: 2009-04-01 10:34:31 -0700 (Wed, 01 Apr 2009)
      Log Message:
      the library path, because it wasn't working correctly in some cases
      and it is no longer necessary due to revision 5524.
      tests Passed: checkintests, performance testsuite, FlexBuilder
      outputFolder JUnit tests
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: Pete F.
      Code-level description of changes:
      CompilerSwcContext.java
      Removed updateRemovedSources() and it's usage.
      CompilerAPI.java
      Removed deleteRemovedSwcSources(), renamed
      deleteObsoletedSwcSources() to reportObsoletedSwcSources(), and
      deleteShadowedSwcSources() to reportShadowedSwcSources().
      Updated validateCompilationUnits() to no longer report
      DependentFileNoLongerExists.
      SwcCache.java
      Removed "removed" and "updated" variables, their getters, and the
      code that initialized them.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcGroup.java
