0 Replies Latest reply on Apr 1, 2009 3:13 PM by (Ryan_Frishberg)
    [svn:fx-trunk] 5859: Adding FLVPlayback source code to Flex 4 project, rather than using a pre-built SWC.
      Revision: 5859
      Author: rfrishbe@adobe.com
      Date: 2009-04-01 16:13:22 -0700 (Wed, 01 Apr 2009)
      Log Message:
      Some video PARB changes:
      Class Name Changes:
      Rename VideoDisplay -> VideoPlayer
      Combine MetadataEvent and VideoEvent into VideoEvent
      Video property/method changes:
      isLive -> live
      isPlaying -> playing
      isMuted -> muted
      mute(), unmute() -> muted getter/setter
      Also fixed a bug where VideoPlayer wasn't properly re-dispatching events.
      QE Notes: -
      Doc Notes: -
      Bugs: -
      Reviewer: Deepa
      tests: checkintests
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/defaults-3.0.0.css
      flex/sdk/trunk/frameworks/projects/flex4/defaults.css
      flex/sdk/trunk/frameworks/projects/flex4/src/Flex4Classes.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/GroupBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/VideoEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/VideoElement.as
      flex/sdk/trunk/frameworks/spark-manifest.xml
      Added Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/AutoLayoutEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/ComponentVersion.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/ConnectClient.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/ConnectClientDynamicStream.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/ConnectClientNative.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/DVRManager.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/DynamicStream.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/DynamicStreamItem.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/FMSCapabilities.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/FPADManager.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/FPMediaCapabilities.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/INCManager.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/IVPEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/LayoutEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/MetadataEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/NCManager.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/NCManagerDynamicStream.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/NCManagerNative.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/ParseResults.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/QueuedCommand.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/ReconnectClient.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/SMILManager.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/VideoAlign.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/VideoError.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/VideoEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/VideoPlayer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/VideoPlayerClient.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/VideoProgressEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/VideoScaleMode.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/VideoState.as
      flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/flvplayback_internal.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoPlayer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoPlayer.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerMuteButtonSki n.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerPlayPauseButt onSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerSkin.mxml
      Removed Paths:
      flex/sdk/trunk/frameworks/libs/videoPlayer.swc
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoDisplay.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoDisplay.png
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/MetadataEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoDisplayMuteButtonSk in.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoDisplayPlayPauseBut tonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoDisplaySkin.mxml
