0 Replies Latest reply on Apr 10, 2008 9:38 AM by (Jono_Spiro)
    [svn] 1176: compiler: moving all the graphing classes to...
      Revision: 1176
      Author: jspiro@adobe.com
      Date: 2008-04-10 10:38:20 -0700 (Thu, 10 Apr 2008)
      Log Message:
      compiler: moving all the graphing classes to... the util.graph package (ala asc)!
      Bugs: n/a
      QA: No
      Doc: No
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcMovie.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/ConsoleApplication.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/DependencyWalker.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/FlexMovie.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/SimpleMovie.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Project.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Algorithms.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/DependencyGraph.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Edge.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Graph.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Vertex.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Visitor.java
      Removed Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/DependencyGraph.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Algorithms.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Edge.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Graph.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Vertex.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Visitor.java
