0 Replies Latest reply on Apr 2, 2009 11:57 AM by (Paul_Reilly)
    [svn:fx-trunk] 5886: * Some deprecation related fixes.
      Revision: 5886
      Author: preilly@adobe.com
      Date: 2009-04-02 12:57:10 -0700 (Thu, 02 Apr 2009)
      Log Message:
      tests Passed: checkintests, mxmlcunit Deprecation
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-18802
      API Change: NO
      Reviewer: Peter D.
      Code-level description of changes:
      asc/src/java/macromedia/asc/embedding/LintEvaluator.java
      Removed ignoreSynthesizedCode, it's setter, and it's usage,
      because it wasn't working.
      compiler/src/java/flex2/compiler_en.properties
      Added as3.SyntaxTreeEvaluator.VariableLevelResourceBundleMetaDataDeprecated.
      compiler/src/java/flex2/compiler/as3/As3Compiler.java
      Removed LintEvaluator.setIgnoreSynthesizedCode() call.
      compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
      Modified processResourceBundle() to report a deprecated warning
      for variable level ResourceBundle metadata.
      compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Modified addDescriptorInitializerFragments() to associate a unique
      position with the type's GetExpressionNode, so if it results in an
      error or warning, we report the Mxml line number.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-18802
      Modified Paths:
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/LintEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
