0 Replies Latest reply on Apr 10, 2008 1:10 PM by (Jono_Spiro)
    [svn] 1183: compiler: Finished off generics warnings in graph, they' re bulletproof now (as long as they're not rounds of depleted uranium).
    Level 1
      Revision: 1183
      Author: jspiro@adobe.com
      Date: 2008-04-10 14:10:12 -0700 (Thu, 10 Apr 2008)
      Log Message:
      compiler: Finished off generics warnings in graph, they're bulletproof now (as long as they're not rounds of depleted uranium).
      * Improved the generics in other places and took advantage of enhanced for loops in some nasty iterators
      Bugs: n/a
      QA: Yes, I'm done with the cleanup so it's a good time to run the suite and see what damage I have done!
      Doc: No
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Assets.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Algorithms.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/DependencyGraph.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Edge.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Graph.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Vertex.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Visitor.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/ConsoleApplication.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/SimpleMovie.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcPreLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Project.java
