0 Replies Latest reply on Apr 3, 2009 11:51 AM by (Jim_Murphy)
    [svn:fx-trunk] 5914: Merge i11.5 revisions 5871-5872,5883,5885,5902 -> trunk
    Level 1
      Revision: 5914
      Author: jimurphy@adobe.com
      Date: 2009-04-03 12:51:17 -0700 (Fri, 03 Apr 2009)
      Log Message:
      Modified Paths:
      flex/sdk/trunk/frameworks/air-config.xml
      flex/sdk/trunk/frameworks/build.xml
      flex/sdk/trunk/frameworks/flex-config.xml
      flex/sdk/trunk/frameworks/halo-manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/defaults.css
      flex/sdk/trunk/frameworks/projects/airframework/spark-air-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransform.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformMove.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformMove3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformRotate.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformRotate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformScale.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransformScale3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/GraphicEleme nt.as
      flex/sdk/trunk/frameworks/spark-manifest.xml
      flex/sdk/trunk/frameworks/tests/states/statefulNodes.mxml
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
      Added Paths:
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/effectClasses/AnimateTransform Instance.as
      Property Changed:
      flex/sdk/trunk/
