0 Replies Latest reply on Apr 3, 2009 1:27 PM by (Paul_Reilly)
    [svn:fx-trunk] 5916: * Fixed mxunit test failure caused by revision 5874.
      Revision: 5916
      Author: preilly@adobe.com
      Date: 2009-04-03 14:27:54 -0700 (Fri, 03 Apr 2009)
      Log Message:
      tests Passed: checkintests, mxunit Namespaces\MultipleManifests\MultipleManifest_MapToSameClass.mxml
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: Pete F.
      Code-level description of changes:
      tools/oem/Application.java
      tools/oem/Library.java
      tools/Compc.java
      tools/Fcsh.java
      tools/Mxmlc.java
      tools/WebTierAPI.java
      compiler/asdoc/AsDocAPI.java
      Modified CompilerAPI.compile() calls to pass in the current NameMappings.
      tools/PreLink.java
      Modified run() to pass the NameMappings object into
      processMainUnit().
      Modified processMainUnit() to use the passed in NameMappings
      object instead of creating a new one.
      tools/CompcPreLink.java
      compiler/PreLink.java
      Added NameMappings param to run().
      compiler/CompilerAPI.java
      Modified compile() to take a NameMappings arg and to pass than
      into PreLink.run().
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/PreLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcPreLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/WebTierAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
