0 Replies Latest reply on Apr 15, 2008 10:33 AM by (Paul_Reilly)
    [svn] 1220: Improved AST generation enough to pass all the mxunit compiler and
    Level 1
      Revision: 1220
      Author: preilly@adobe.com
      Date: 2008-04-15 11:33:14 -0700 (Tue, 15 Apr 2008)
      Log Message:
      data binding tests. In theory, this should allow us to compile the
      performance suite applications now. AST generation is still off by
      default. Additional testing and some loose ends need to be tied up
      before we flick the switch on AST generation.
      checkintests Passed: YES
      Needs QA: Not yet.
      Needs DOC: NO
      API Change: NO
      Code-level description of changes:
      lib/asc.jar
      Built with NodeFactory.java change.
      modules/asc/src/java/macromedia/asc/parser/NodeFactory.java
      Added getContext() to make life easier for AST generation code.
      modules/compiler/src/java/flex2/compiler/as3/EmbedEvaluator.java
      Modified evaluate(Context, MetaDataNode) to handle the case when
      the Context's input is null by leaving the line number and column
      number unset and by using the Context's scriptName instead of the
      input's origin.
      modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      Added generateMxInternalQualifiedIdentifier() from
      ImplementationGenerator.
      Modified the generateVariable*() methods to use a NodeFactory
      instead of a Context.
      modules/compiler/src/java/flex2/compiler/SymbolTable.java
      Modified constructor to temporarily set the ABC version to 0, so
      we target the Flash 9 Player. Jono is working on wiring up the
      configuration to control this.
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.java
      Modified generateDefinitionBody() by adding support for Repeaters.
      Added generateChildDescriptorVariable(),
      generateInitializeRepeater(), and generateRepeaterChildDescriptorLoop().
      Modified formatExpr() to handle BindingExpression with an
      "undefined" value and classType with a "this" value correctly.
      Implemented asXmlLiteral().
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/VisualChildInitializer.java
      Added extractName(), generateChildRepeaters(), and generateElse().
      Implemented generateAssignExpr().
      modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
      Added generateNamespaceDeclarations().
      modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Made addDescriptorInitializerFragments(), addDescriptorEvents,
      addDescriptorEffectNames, addDescriptorStylesAndEffects,
      addDescriptorProperties() and getDescriptorInitializerFragments()
      static, so that VisualChildInitializer can use them.
      Removed literal(), because it's no longer used.
      Removed generateMxInternalQualifiedIdentifier(), which was moved
      to AbstractSyntaxTreeUtil.
      Modified generateClassDefinition() to more closely follow the
      Velocity templates.
      Modified generateComponentStyleSettings() by implementing support
      for effects.
      Added generateDocumentAssignment().
      Modified Paths:
      flex/sdk/trunk/lib/asc.jar
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/NodeFactory.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/VisualChildInitiali zer.java
