0 Replies Latest reply on Apr 16, 2008 11:44 PM by (Paul_Reilly)
    [svn] 1269: Fixed issues blocking the performance testsuite from compiling cleanly
    Level 1
      Revision: 1269
      Author: preilly@adobe.com
      Date: 2008-04-17 00:44:18 -0700 (Thu, 17 Apr 2008)
      Log Message:
      with -generate-abstract-syntax-tree turned on.
      checkintests Passed: YES
      Needs QA: Not yet
      Needs DOC: NO
      API Change: NO
      Code-level description of changes:
      swfutils/src/java/flash/swf/tools/SyntaxTreeDumper.java
      Modified evaluate(Context, LiteralXMLNode) to show is_xmllist.
      Modified evaluate(Context, IncludeDirectiveNode) to show
      in_this_include and filespec.
      compiler/src/java/flex2/compiler/as3/EmbedEvaluator.java
      Modified evaluate(Context, MetaDataNode) to use the
      Context.input.origin if it's available and only use scriptName()
      when it's not. This is a less risky change than using
      scriptName() all the time.
      compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      Modified generateImport() and generateProgram() to use
      generatePackageName().
      Added generatePackageName().
      compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension.java
      Modified generateAccessorFunction() to use AbstractSyntaxTreeUtil.parse().
      compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.java
      Implemented asXMLList().
      compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      Modified generateImplementationAST() to pass the source's parent
      into the new TextFile.
      compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Removed generateTypeExpression(), because it's already in
      Modified a few places to use
      AbstractSyntaxTreeUtil.generateTypeExpression().
      Modified generateScripts() to use addAll() instead of
      NodeFactory.statementList(), because that has side effects for
      IncludeDirectiveNode's.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SyntaxTreeDumper.java
