0 Replies Latest reply on Apr 17, 2008 11:25 AM by (Jono_Spiro)
    [svn] 1274: SDK-15275 - Mxmlc needs setting to control ASC so that correct bytecode is generated when targeting FP 10
      Revision: 1274
      Author: jspiro@adobe.com
      Date: 2008-04-17 12:25:21 -0700 (Thu, 17 Apr 2008)
      Log Message:
      * --target-player now correctly controls the SWFs that are generated
      * eliminated SymbolTable workaround from earlier this week
      * updated asc.jar with change to ContextStatics (API addition)
      Bugs: SDK-15275
      QA: Yes, I set target-player to 9 in the DefaultsConfigurator, so I am interested if there is any situation where the DC is bypassed -- e.g. OEM API
      Doc: Maybe -- I don't know what the docs for target-player look like, I think it's implied that it produces correct SWFs...
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-15275
      Modified Paths:
      flex/sdk/trunk/lib/asc.jar
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/ContextStatics.java
      flex/sdk/trunk/modules/compiler/src/java/flash/swf/tools/as3/EvaluatorAdapter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/PersistenceStore.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/DefaultsConfigurator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Target.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ApplicationData.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMUtil.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/Movie.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SwfxPrinter.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SyntaxTreeDumper.java
