0 Replies Latest reply on Feb 21, 2008 6:42 PM by (GordonSmith)
    [svn] 616: Update trunk/modules/ asc to the asc mainline from Mercurial changeset 196.
    Level 1
      Revision: 616
      Author: gosmith@adobe.com
      Date: 2008-02-21 18:42:07 -0800 (Thu, 21 Feb 2008)
      Log Message:
      Update trunk/modules/asc to the asc mainline from Mercurial changeset 196.
      Modified Paths:
      flex/sdk/trunk/modules/asc/bin/jvm.config
      flex/sdk/trunk/modules/asc/src/java/adobe/abc/GlobalOptimizer.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/abc/AbcParser.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/abc/ConstantPool.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/abc/Decoder.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/abc/Encoder.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/abc/OpcodeVisitor.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/abc/Opcodes.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/abc/Optimizer.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/abc/Printer.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/abc/Scanner.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/abc/Visitor.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/BatchCompiler.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/Compiler.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/CompilerPlug.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/ErrorConstants.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/LintEvaluator.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/Main.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/ScriptCompiler.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/avmplus/ActionBlockConstants .java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/avmplus/ActionBlockEmitter.j ava
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/avmplus/ByteCodeFactory.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/avmplus/Features.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/avmplus/GlobalBuilder.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/avmplus/RuntimeConstants.jav a
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/BinaryExpressionNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Evaluator.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/IncrementNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/InputBuffer.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/LiteralNumberNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/MetaDataEvaluator.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/NodeFactory.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/NodePrinter.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Scanner.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/StatementListNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Tokens.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/UnaryExpressionNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/CodeGenerator.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/ConfigurationEvaluator.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/ConstantEvaluator.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/Emitter.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/FlowAnalyzer.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/ObjectValue.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/ReferenceValue.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/TypeInfo.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/TypeValue.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/Context.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/ContextStatics.java
      flex/sdk/trunk/modules/asc/src/localized_strings/EN/ErrorConstants.xml
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DiffDataTypesWithNullUndefinedWarn_ warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/testconfig.txt
      flex/sdk/trunk/modules/asc/test/sanity/build.xml
      flex/sdk/trunk/modules/asc/test/sanity/regress/b155288.as
      flex/sdk/trunk/modules/asc/test/sanity/regress/b191112.as
      flex/sdk/trunk/modules/asc/test/sanity/regress/class_ctor.as
      flex/sdk/trunk/modules/asc/test/sanity/regress/class_ctor.log
      flex/sdk/trunk/modules/asc/test/sanity/tests/b155288.as
      flex/sdk/trunk/modules/asc/test/sanity/tests/b191112.as
      flex/sdk/trunk/modules/asc/test/sanity/tests/class_ctor.as
      Added Paths:
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/TypeIdentifierNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/UseNumericNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/UsePragmaNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/UsePrecisionNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/UseRoundingNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/Decimal128.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/Decimal128Context.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/DecimalNumberConstant.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/DenselyPackedDecimal.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/DoubleNumberConstant.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/IntNumberConstant.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/NumberConstant.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/NumberUsage.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/UintNumberConstant.java
      flex/sdk/trunk/modules/asc/test/sanity/regress/decimal1.as
      flex/sdk/trunk/modules/asc/test/sanity/regress/decimal1.log
      flex/sdk/trunk/modules/asc/test/sanity/tests/decimal1.as
