0 Replies Latest reply on Apr 18, 2008 2:55 PM by (esolovey@adobe.com)
    [svn] 1305: Avoid NPE' s on the client when record-message-times or record-message-sizes and tracing are enabled and the message received by the client is not stamped with performance information .
      Revision: 1305
      Author: esolovey@adobe.com
      Date: 2008-04-18 15:55:42 -0700 (Fri, 18 Apr 2008)
      Log Message:
      Avoid NPE's on the client when record-message-times or record-message-sizes and tracing are enabled and the message received by the client is not stamped with performance information.
      [ private comments below ]
      Bug: LCDS-224
      Checkintests: Pass
      The case that discovered this issue is a Connect message for a DataService using RTMP which does not get stamped as it is processed completely within the RTMP endpoint and does not make it all the way to the MessageBroker.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/LCDS-224
      Modified Paths:
      flex/sdk/branches/3.0.x/frameworks/projects/rpc/src/mx/messaging/MessageAgent.as
      flex/sdk/branches/3.0.x/frameworks/projects/rpc/src/mx/messaging/channels/NetConnectionCh annel.as
      flex/sdk/branches/3.0.x/frameworks/projects/rpc/src/mx/messaging/channels/PollingChannel. as
      flex/sdk/branches/3.0.x/frameworks/projects/rpc/src/mx/messaging/messages/MessagePerforma nceUtils.as
