0 Replies Latest reply on Apr 18, 2008 3:28 PM by (Jono_Spiro)
    [svn] 1307: modules: added support for automatically adding " use namespace X", depending on the -target-player value
      Revision: 1307
      Author: jspiro@adobe.com
      Date: 2008-04-18 16:28:33 -0700 (Fri, 18 Apr 2008)
      Log Message:
      modules: added support for automatically adding "use namespace X", depending on the -target-player value
      * similar to how we add "use namespace AS3"
      * symmetric with ASC's -use feature, however we don't have equivalent commandline support yet
      Bugs: n/a
      QA: Nothing in particular, except for testing the new functionality of -target-player (email me about this)
      Doc: Maybe: If we doc about "use namespace AS3" being added to all Flex compiles, we may want to talk about this.
      Reviewers: Pete and Erik
      Modified Paths:
      flex/sdk/trunk/frameworks/flex-config.xml
      flex/sdk/trunk/lib/asc.jar
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/BatchCompiler.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/Compiler.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/ScriptCompiler.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/Context.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/ContextStatics.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/MetaDataParser.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/DefaultsConfigurator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/AtEmbed.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SwfxPrinter.java
