0 Replies Latest reply on Apr 21, 2008 9:20 AM by (Erik_Tierney)
    [svn] 1324: Fix Vector problems where mxmlc would error with messages like "Vector.<Foo> not compatible with Vector.<Foo>".
      Revision: 1324<br />Author:   tierney@adobe.com<br />Date:     2008-04-21 10:20:07 -0700 (Mon, 21 Apr 2008)<br /><br />Log Message:<br />-----------<br />Fix Vector problems where mxmlc would error with messages like "Vector.<Foo> not compatible with Vector.<Foo>".  The problem was that flex uses a lot of different toplevel builders, so the cached Vector class wouldn't always be found and a new one would be generated, causing the mismatch when checking types.  Now we cache the instantiated types in the Vector type itself, of which there should really only be one.<br /><br />Modified Paths:<br />--------------<br />    flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/ReferenceValue.java<br />    flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/TypeValue.java
