0 Replies Latest reply on Apr 21, 2008 9:53 AM by (Jim_Murphy)
    [svn] 1326: Merge 3.0.x[1303,1305] -> trunk
    Level 1
      Revision: 1326
      Author: jimurphy@adobe.com
      Date: 2008-04-21 10:53:00 -0700 (Mon, 21 Apr 2008)
      Log Message:
      3.0.x Logs:
      r1303 | genovese@adobe.com | 2008-04-18 16:17:36 -0400 (Fri, 18 Apr 2008) | 1 line
      Minor ASDoc update - fixed typo
      r1305 | esolovey@adobe.com | 2008-04-18 18:55:42 -0400 (Fri, 18 Apr 2008) | 8 lines
      Avoid NPE's on the client when record-message-times or record-message-sizes and tracing are enabled and the message received by the client is not stamped with performance information.
      [ private comments below ]
      Bug: LCDS-224
      Checkintests: Pass
      The case that discovered this issue is a Connect message for a DataService using RTMP which does not get stamped as it is processed completely within the RTMP endpoint and does not make it all the way to the MessageBroker.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/LCDS-224
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/sliderClasses/SliderThumb.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/MessageAgent.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/channels/NetConnectionChannel.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/channels/PollingChannel.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/messages/MessagePerformanceUtils. as
      Property Changed:
      flex/sdk/trunk/
