0 Replies Latest reply on Apr 23, 2008 9:44 AM by (Paul_Reilly)
    [svn] 1356: Incorporated Pakash's InterfaceCompiler AST generation work.
    Level 1
      Revision: 1356
      Author: preilly@adobe.com
      Date: 2008-04-23 10:44:48 -0700 (Wed, 23 Apr 2008)
      Log Message:
      checkintests Passed: YES
      Needs QA: Not yet
      Needs DOC: NO
      API Change: NO
      Code-level description of changes:
      i18n/I18nCompiler.java
      Removed profile() from the As3Configuration subclass, because it's
      not used.
      mxml/InterfaceGenerator.java
      Initial checkin.
      mxml/AbstractGenerator.java
      Initial checkin.
      mxml/InterfaceCompiler.java
      not used.
      Modified parse2() to call generateSkeletonAST() when
      -generate-abstract-syntax-tree is set to true.
      Modified generateSkeleton() to return a Source object to be more
      consistent with ImplementationCompiler.
      Added generateSkeletonAST().
      Modified compileInterface() to skip the metadataOnly check when
      mxml/ImplementationGenerator.java
      Modified class to extend AbstractGenerator. As a result, removed
      context, nodeFactory, and programNode variables. Also removed
      generateMetaData(), getContext(), and getSyntaxTree(), which were
      moved to AbstractGenerator, so they could be shared with
      InterfaceGenerator.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/I18nCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/AbstractGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
