0 Replies Latest reply on Apr 24, 2008 6:15 AM by (Paul_Reilly)
    [svn] 1378: Fixed some recently introduced mxunit databinding failures when
      Revision: 1378
      Author: preilly@adobe.com
      Date: 2008-04-24 07:15:10 -0700 (Thu, 24 Apr 2008)
      Log Message:
      -generate-abstract-syntax-tree is turned on.
      checkintests Passed: YES
      Needs QA: No
      Needs DOC: NO
      API Change: NO
      Code-level description of changes:
      AbstractSyntaxTreeUtil.java
      Added some asserts to parse() to help catch ASC changes early.
      binding/DataBindingExtension.java
      Modified both generateAccessorFunction()'s to no longer skip the
      first two nodes as AbstractSyntaxTreeUtil.parse() handles this.
      Modified generateInitFunctionCommon() to set the
      FunctionSignatureNode's void_anno to true.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
