0 Replies Latest reply on Apr 24, 2008 1:15 PM by (Jim_Murphy)
    [svn] 1398: -fix flex-sdk-description. xml to use regular expression to update and not copying files around so they could be updated
    Level 1
      Revision: 1398
      Author: jimurphy@adobe.com
      Date: 2008-04-24 14:15:04 -0700 (Thu, 24 Apr 2008)
      Log Message:
      -fix flex-sdk-description.xml to use regular expression to update and not copying files around so they could be updated
      -moving flex-sdk-description.xml to the root directory from the collateral/en_US directory where it will be updated everytime someone runs ant main
      -removed flex-sdk-description.xml from being deleted in the clean target
      -fixed package target to not call clean, main - in order to get a package you now have to call ant clean main package. I also removed the repackage target since it is not used any longer.
      I know there is some more clean up that can be done in here as far as packaging is concerned!
      Modified Paths:
      flex/sdk/trunk/build.xml
      Added Paths:
      flex/sdk/trunk/flex-sdk-description.xml
      Removed Paths:
      flex/sdk/trunk/collateral/en_US/flex-sdk-description.xml
