0 Replies Latest reply on Apr 24, 2008 4:45 PM by (GordonSmith)
    A new expression evaluator.
    Level 1
      When you evaluate an expression with a function call, any side effects
      will be permanent, right?
      - Gordon
      -----Original Message-----
      From: Mike Morearty [mailto:member@adobeforums.com]
      Sent: Thursday, April 24, 2008 5:18 PM
      To: flexsdk-commits@adobeforums.com
      Subject: [svn] 1405: Major debugger checkin: A new expression evaluator.
      A new discussion was started by Mike Morearty in
      Commits --
      Revision: 1405
      Author: mmoreart@adobe.com
      Date: 2008-04-24 17:18:24 -0700 (Thu, 24 Apr 2008)
      Log Message:
      Major debugger checkin: A new expression evaluator. Previously, the
      debugger used a somewhat crude parser that handled simple expressions
      correctly but failed on many more complex expressions. The new one
      handles many more cases that used to fail, including:
      - Most E4X expressions such as x.y, x.@y, x..y; the main thing that is
      not supported is E4X filters such as x.(@y==3)
      - Function calls, e.g. myvar.toString(), mystring.charAt(0) (this
      requires player 10)
      - References to global classes and variables, e.g. MyClass.myStatic,
      Math.max(a,b,c), String(myvar), etc. (this requires player 10)
      - Floating-point arithmetic, e.g. myFloat + 1.5
      - mystring.length
      - operator 'new', e.g. foo = new MyClass()
      - Regular expressions, e.g. mystring.match(/regex/ig)
      - Array literals, e.g. myarray = ["my", "literal", "array"]
      - Propertly tells the difference between undefined, null, NaN, Intinity,
      true, false
      - Ternary operator: a ? b : c
      - Almost all other operators e.g. ===, !==, and >>> (still doesn't
      support instanceof, in, is, as)
      Note, fdb.jar now depends on mxmlc.jar and asc.jar.
      Also in this checkin: Did some prep work for the day, someday in the
      future, when there is a 64-bit Flash player. Variable id's are now 64
      bits (long) instead of 32 bits (int).
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/development/eclipse/java/flex-compiler/.classpath
      flex/sdk/trunk/development/eclipse/java/flex-debugger/.classpath
      flex/sdk/trunk/modules/debugger/build.xml
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/Session.ja
      va
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/Value.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/Variable.j
      ava
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/VariableTy
      pe.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/Watch.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/concrete/D
      Manager.java
      Message.java
      Module.java
      Protocol.java
      StackContext.java
      SwfInfo.java
      Value.java
      Variable.java
      Watch.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/concrete/P
      layerSession.java
      layerSessionManager.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/events/Deb
      ugEvent.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/expression
      /ASTBuilder.java
      /Context.java
      /IASTBuilder.java
      /ValueExp.java
      /expression_en.properties
      /expression_ja.properties
      flex/sdk/trunk/modules/debugger/src/java/flash/util/URLHelper.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/DebugCL
      I.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/Express
      ionCache.java
      ionContext.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/Extensi
      ons.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/Locatio
      nCollection.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/StringI
      ntArray.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/Variabl
      eFacade.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/WatchAc
      tion.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/fdb_en.
      properties
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/fdb_ja.
      properties
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/debug/DebugModule.jav
      a
      Added Paths:
      /DebuggerEvaluator.java
      /DebuggerExpression.java
      /ECMA.java
      /ExpressionEvaluatorException.java
      Removed Paths:
      /AddExp.java
      /AndExp.java
      /ArithmeticExp.java
      /AssignmentExp.java
      /BitwiseExp.java
      /BooleanExp.java
      /ConstantBooleanExp.java
      /ConstantExp.java
      /DivExp.java
      /DotExp.java
      /EqExp.java
      /GTEqExp.java
      /GTExp.java
      /IncompleteExpressionException.java
      /IndirectionExp.java
      /InternalVariableExp.java
      /LShiftExp.java
      /LTEqExp.java
      /LTExp.java
      /LogicAndExp.java
      /LogicNotExp.java
      /LogicOrExp.java
      /ModExp.java
      /MultExp.java
      /NeqExp.java
      /NoChildException.java
      /NonTerminalExp.java
      /NotExp.java
      /Operator.java
      /OrExp.java
      /RShiftExp.java
      /RelationalExp.java
      /SingleArgumentExp.java
      /StringExp.java
      /SubExp.java
      /SubscriptExp.java
      /TerminalExp.java
      /UnknownOperationException.java
      /VariableExp.java
      /XorExp.java
      View/reply at
      Replies by email are OK.
      Use the unsubscribe form at
      to
      cancel your email subscription.
