0 Replies Latest reply on May 1, 2008 12:54 PM by (Paul_Reilly)
    [svn] 1514: Attempt to fix negative performance impact due to revision 1456 .
      Revision: 1514
      Author: preilly@adobe.com
      Date: 2008-05-01 13:54:28 -0700 (Thu, 01 May 2008)
      Log Message:
      Attempt to fix negative performance impact due to revision 1456.
      checkintests Passed: YES
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewed by: pfarland
      Code-level description of changes:
      PositionOffsetter.java
      Deleted because it's no longer used.
      AbstractSyntaxTreeUtil.java
      Modified parse() method to set the start position to the end
      position of the previous code fragment, instead of sweeping
      through the tree of Node's offsetting the position afterwards.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      Removed Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/PositionOffsetter.java
