0 Replies Latest reply on May 6, 2008 9:01 AM by (Jim_Murphy)
    [svn] 1568: -new builds of avmplus Release_Debugger - build 535
    Level 1
      Revision: 1568
      Author: jimurphy@adobe.com
      Date: 2008-05-06 10:01:52 -0700 (Tue, 06 May 2008)
      Log Message:
      -update tests to pass with this avmplus version
      -update runtests.py
      -correct variable name for playerglobalabc (was playerglobal)
      -writes out results.properties if there are failures. this is for use with my build file to fail the build if there are failures
      -add asc-tests target in build.xml
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/modules/asc/abc/builtin.abc
      flex/sdk/trunk/modules/asc/bin/linux/avmplus_s
      flex/sdk/trunk/modules/asc/bin/mac/shell_s
      flex/sdk/trunk/modules/asc/bin/mac/shell_s_ppc
      flex/sdk/trunk/modules/asc/bin/windows/avmplus_s.exe
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/AccPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ActivateTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/AddListenerWarn2.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/AddedTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/AsBroadcasterClassWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/BitmapDataWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ButtonMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMactive.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMbutton.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMcall.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMcapabilities.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMcolor.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMloadVars.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMmovieClipLoader.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMmovieclip.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMnetStream.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMobject.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMselection.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMsharedObject.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMsound.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMstage.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMstylesheet.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMsubstring.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMsystem.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMtextField.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMtextFormat.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMtimeout.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMvideo.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMxmlSocketTest.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMxmldoc.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CameraEventsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CameraGetWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CancelTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ChangeTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CharCodeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ChrWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ClearIntervalWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CloseTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ColorMethodsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CompleteTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ConnectTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContainerMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuCopyWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuEventsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuForward_BackWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuItemCopyWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuItemEventsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuMethodsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DateWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DeactivateTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DeleteKeyWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DiffDataTypesWithNullUndefinedWarn. err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectAlphaWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectHeightWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectMaskWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectMouseXWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectMouseYWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectNameWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectParentWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectRotationWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectScaleXWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectScaleYWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectVisibleWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectWidthWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectXWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectYWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DuplicateMovieClipWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/EnterFrameTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FileReferenceEventsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FileReferenceListWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FileReferenceMethodsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FocusInTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FocusOutTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/GetCodeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/GetPropertyWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/GlobalFunctionsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/GotoAndPlayWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/GotoAndStopWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/IMEMethodsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/Id3TypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageFilterMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageLoaderInfoMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageSpriteMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImeEventMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/InitTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/IsDownWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/IsToggledWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/KeyFocusChangeTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/KeyMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/KeyPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/KeyboardClassConstWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/KeyboardClassMethodsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LengthWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LineMetricsMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ListPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LoadMovieNumWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LoadMovieWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LoadVariablesWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LoadVarsMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LocalConnectionWarnings.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MbChrWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MbLengthWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MbOrdWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MbSubStringWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MenuEventMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MicrophoneEventsMethodsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MouseClassEventsMethodsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MouseFocusChangeTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MouseLeaveTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MovieClipEvents.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MovieclipLoaderClassWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MovieclipUrlWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/NetConnIsConnectedPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/NextFrameWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/NumPadWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/OpenTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/OrdWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PGDNWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PGUPWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PlayWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PrintAsBitmapNumWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PrintAsBitmapWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PrintNumWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ProtoPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/RandomWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/RemoveMovieclipWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/RemovedTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/RenderTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ResizeTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ScalingGridPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ScrollTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SelectTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SetIntervalWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SetPropertyWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SocketIsConnectedPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SoundCompleteTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StageQualityWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StartDragWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StopAllSoundsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StopDragWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StopWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SubStringWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SystemCapabilitiesMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SystemCapabilitiesPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TabChildrenChangeTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TabEnabledChangeTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TabIndexChangeTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextExtentsMethWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextExtentsPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextFieldBottomScrollPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextFieldScrollPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextSnapshotClassWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextSnapshotMethodsWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ToggleHighQualityWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/URLStreamIsConnectedPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/UnloadMovieNumWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/UnloadTypeWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/UnsupportedAS2FunctionWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/UnsupportedAS2PropertyWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/VersionPropWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/XYZQualityWarn.err
      flex/sdk/trunk/modules/asc/test/compiler/runtests.py
