0 Replies Latest reply on May 8, 2008 10:31 AM by (Jono_Spiro)
    [svn] 1623: SDK-15294: Update SignatureEvaluator to handle Vector.<*>
    Level 1
      Revision: 1623
      Author: jspiro@adobe.com
      Date: 2008-05-08 11:31:40 -0700 (Thu, 08 May 2008)
      Log Message:
      * I re-enabled SignatureExtension failure warnings since ASC is in churn (if a soft-assertion (e.g. unexpected code path) fails, I assume that the signature is unsafe to use and revert to conservative (slow) invalidation behavior). Without these warnings on, you will not be aware of this, and therefore it will not get fixed. A bug has been filed to disable it for release.
      Reviewer: Pete
      Bugs: SDK-15294
      QA: Yes, full signature suite, please. And we need tests for Vector.
      Doc: No
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-15294
      Modified Paths:
      flex/sdk/trunk/lib/asc.jar
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/NodeMagic.java
