0 Replies Latest reply on May 9, 2008 7:28 AM by (Paul_Reilly)
    [svn] 1631: Fixed Hospital app compilation by using the new OffsetInputBuffer.
    Level 1
      Revision: 1631
      Author: preilly@adobe.com
      Date: 2008-05-09 08:28:23 -0700 (Fri, 09 May 2008)
      Log Message:
      Reduced String.intern() calls by telling ASC not to intern constants,
      which are used during direct AST generation, because they have already
      been interned.
      testsuites Passed: checkintests, mxunit compiler, mxmlcunit compiler
      (one new unrelated failure due to signature
      changes), performance
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: tierney, pfarland
      Code-level description of changes:
      modules/asc/src/java/macromedia/asc/parser/NodeFactory.java
      Modified identifier() to use a constant for "arguments" and to use
      == comparison since both sides have been interned.
      Added new identifier() and literalString() variants to support
      String.intern() avoidance.
      modules/asc/src/java/macromedia/asc/parser/LiteralStringNode.java
      Added new constructor to support String.intern() avoidance.
      modules/asc/src/java/macromedia/asc/parser/Scanner.java
      Added new constructor to support passing in a custom InputBuffer.
      modules/asc/src/java/macromedia/asc/parser/Parser.java
      modules/asc/src/java/macromedia/asc/parser/IdentifierNode.java
      Added constant for "*" and modified setName() to use == comparison
      modules/compiler/src/java/flex2/compiler/as3/OffsetInputBuffer.java
      Initial checkin.
      modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      Modified parse() use an OffsetInputBuffer.
      Added intern avoidance support.
      modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension.java
      modules/compiler/src/java/flex2/compiler/mxml/rep/AtResource.java
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/EffectInitializer.java
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.java
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/StyleInitializer.java
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/EventInitializer.java
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/VisualChildInitializer.java
      modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
      modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
      modules/compiler/src/java/flex2/compiler/mxml/AbstractGenerator.java
      modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Modified Paths:
      flex/sdk/trunk/lib/asc.jar
      flex/sdk/trunk/modules/asc/build/java/build.xml
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/IdentifierNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/LiteralStringNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/NodeFactory.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Scanner.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/CodeFragmentsInputBuffer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/AbstractGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/AtResource.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/EffectInitializer.j ava
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/EventInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/StyleInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/VisualChildInitiali zer.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/OffsetInputBuffer.java
