0 Replies Latest reply on May 9, 2008 1:49 PM by (GordonSmith)
    [svn] 1649: Renamed our customized Velocity JAR from mm-velocity-1.4. jar to velocity-dep-1.4-flex.jar.
      Revision: 1649
      Author: gosmith@adobe.com
      Date: 2008-05-09 14:49:18 -0700 (Fri, 09 May 2008)
      Log Message:
      Renamed our customized Velocity JAR from mm-velocity-1.4.jar to velocity-dep-1.4-flex.jar.
      The standard Velocity name for this JAR, which is built by Velocity's "jar-dep" target, is velocity-dep-1.4.jar. We append "-flex" to indicate that we've customized it, just as for our customized Batik JAR.
      This change affected the mxmlc classpath in modules/compiler/build.xml, the packaging scripts, and the Eclipse projects.
      I also renamed mm-velocity-LICENSE.txt and mm-velocity-NOTICE.txt to drop the "mm-" prefix.
      Bugs: -
      QA: No
      Doc: No
      Reviewer: Jono
      Ticket Links:
      http://bugs.adobe.com/jira/browse/velocity-1
      http://bugs.adobe.com/jira/browse/dep-1
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/development/eclipse/java/flex-jars/.classpath
      flex/sdk/trunk/modules/compiler/build.xml
      Added Paths:
      flex/sdk/trunk/lib/velocity-LICENSE.txt
      flex/sdk/trunk/lib/velocity-NOTICE.txt
      flex/sdk/trunk/lib/velocity-dep-1.4-flex.jar
      Removed Paths:
      flex/sdk/trunk/lib/mm-velocity-1.4.jar
      flex/sdk/trunk/lib/mm-velocity-LICENSE.txt
      flex/sdk/trunk/lib/mm-velocity-NOTICE.txt
